Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-22-2005, 02:14 PM
3rdchild 3rdchild is offline
hot intake problem?
This may be a dumb question but...
The other day i notice that my aluminum cold air intake pipe is really hot - temperature-wise. To hot to touch. I was wondering is this normal? If not then something must be wrong and i can only suspect that its probably robbing me of power.
Old 06-22-2005, 02:42 PM
orestes's Avatar
orestes orestes is offline
Info necessary to answer the question: Year, Make, Model, Specific Cold Air intake, other engine mods, etc.
They can get hot - most of the time it wont matter, if you have some crappy rigged-up setup routed where its not supposed to, then you could have a problem. But Injen and other brands say the heat of the aluminum is not enough to show up on a dyno vs. stock or carbon fiber or whatever.
"I got that hustle in my genes like high blood pressure" -E-40
Old 06-22-2005, 02:49 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: hot intake problem?
the hard fact of cold intake on the KA's.... there all hot.. by the time air arives at the throtle body, it will be hot at that point.
BTW it is normal...
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 06-22-2005, 03:24 PM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
well the reason for the aluminum piping to begin with is to transfer the heat of the air to the atmosphere VIA the metal (which has low insulation properties). So the heat needs to go through the metal first... that's why it's hot. Plus the longer the intake piping is the more effective it is (larger surface area). But at the same time will reduce the responsiveness of the air induction flow. (hence, the short ram intake... but i don't think that makes much of a difference, personally)
1993 RMS13 5MT KA
Old 06-22-2005, 03:46 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
ok...
Heat is measured in Joules your Intake is pulling air fast enough by there that it wont change in temperature...take for example....If you blow air over a HOT HOT piece of meat does the air change in temperature(by more then 1-2 degrees?)? No it doesnt. It doesnt have enough time to change the air with the 35 J that may have transferred into the air... Your intake is damned close to your radiator(maybe touching) so if it wasnt hot i dont know what to tell you...
Old 06-22-2005, 03:47 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
how is that nessicary to awnswer is question?
yes. the aluminum will heat up, moreso on KA intakes since they run right near the radiator. in most cases where you want more power (i.e. full throttle) it wont matter since the air is traveling too fast to heat up any noticable amount. it you really care about 1 degree of IAT you can paint it Silver or gold to reflect heat better... or get that wrap stuff that ties on...
if you really care about Intake Air temp find someone to make a plastic Manifold gasket the S2000 guys say it works wonders.
Old 06-22-2005, 04:16 PM
Re: Re: hot intake problem?
Originally Posted by SHIFT_KA24DE
well the reason for the aluminum piping to begin with is to transfer the heat of the air to the atmosphere VIA the metal (which has low insulation properties). So the heat needs to go through the metal first... that's why it's hot. Plus the longer the intake piping is the more effective it is (larger surface area). But at the same time will reduce the responsiveness of the air induction flow. , personally)
DUDE, ur dead wrong... u think Al is absorbing the heat from the engine bar, hence reducing the heat of the air? WHAAAT???
put it this way, try to suck cold drink out of a straw, easy right and its cold. now do it but make the straw HOT, u will suck hot air.
back to the point, the air intake on the KA is mounted on TOP of the engine, and i air has to travel ACROSS the engine to the throttle. SO air at that point gets hot.
BTW: AL is used bcus its lighter and it cools quick, BUT Al heats up quick too.... (u could use Cu but people what shinny stuff!)
larger surfce area makes for more HOT Al, hence, hot air.. its cool dough, ur engine is ment to run that way.
E.K.
Old 06-22-2005, 04:22 PM
btw, longer air intake, more eror in the reading of air.
my MAF, is gone... i have Fcon, you sould have seen how BAD the reading from the MAF that i had.
by the time air is reached to the throtl body, the reading will be totally diff from the inital reading by the MAF.
so... MAF FAR AWAY from the throttle, BAD reading (the air Accelerating Velocity changes), Al piping, even worth... the temp changes Drematiclly too, (not that it didn't change bfr) .
E.K.
Old 06-22-2005, 06:24 PM
slideways...'s Avatar
slideways... slideways... is offline
MAF too close to TB = bad reading also
i tried it on my old sentra and it kicked out a CE light if the MAF was too close.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 06-22-2005, 08:06 PM
Re: Re: Re: hot intake problem?
i think if you read my comment again you'd notice i didn't say that the Al is absorbing the heat... the atmosphere is.. the Al just acts as the medium to exhange the heat during the process.
fyi... straws are made out of plastic. plastic is an insulator. (used to keep heat/cold in.. not through) (i.e.- thermo cups, electrical wire sleeves, and that polyester/cotton sweater your grandma gave you last X-mas) ... and how do you make straw hot? wouldn't it just melt? Additionally, you place an Aluminum spoon in your hot drink to cool it down faster... hence, the heat transfer from your drink... to the atmosphere... try compare that with a plastic spoon...
you just restated what i said "Al cools quick and heat up quick too..." obviously... if it doesn't, it'll just trap all the heat in. anyway, no point arguing about thermodynamics... it'll just keep on going. let's get back on the subject.
1993 RMS13 5MT KA
Old 06-22-2005, 08:11 PM
i think i mentioned that...
...But at the same time will reduce the responsiveness of the air induction flow. (hence, the short ram intake
so anyway, yes it is normal. No worries.
1993 RMS13 5MT KA
Old 06-22-2005, 11:10 PM
its all goodo bro! lol!
E.K.
