Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-22-2005, 12:35 PM
noholdsbarred noholdsbarred is offline
Question turbo
I'm not sure if this is the right forum, but what is the diameter (inches) of a stock turbo inlet on a 1994 Laser? I want to test the pressure without taking it apart before I buy parts. I tried vfaq.com, but couldn't find any useful info.
2004 Impreza WRX
Old 06-22-2005, 04:25 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: turbo
It's about 2 inches but if you are making the intake pressure tester from vfaq then use something 2.5'' to fit over the inlet. I used a 2.5 inch rubber coupler. The 2'' was almost exactly the same size and had to shave off some rubber to get it to fit.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 06-22-2005, 11:41 PM
joemathews's Avatar
joemathews joemathews is offline
Re: turbo
Pick up a 2.5" rubber coupler from Home Depot. They're sold in the PVC section, and they even come with hose clamps. Find an end-cap that will fit while you're there. I had to pick up valve stems from Wal-Mart because Home Depot didn't have 'em.
1996 Eagle Talon
