Old 06-22-2005, 01:24 PM
americansk8er85 americansk8er85 is offline
Dizzy problems
so my car stalled out 2 weeks ago, checked for spark and had none. so i went to a local junk yard and picked up another distributor for 50 bucks, put that in and it worked great. two days later my car stalls out again. after being towed to my house and i check and no spark! so i assume its the distributor again. does it sound logical that a distributor would last only that long even being from the JY? i was wondering if something could be causing the distributor to break? i know my fuel pump works cause i can hear it when i turn the key, and the same goes for the main relay.
Old 06-22-2005, 03:09 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: Dizzy problems
Have you pulled the cap off and checked the screw that holds the rotor on? That seems to be the culprit of alot of distributor problems in the 4th gens.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 06-22-2005, 03:17 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Dizzy problems
what aftermarket parts do you have on your engine?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 06-22-2005, 03:44 PM
Re: Dizzy problems
i replaced the cap, plugs and rotor when i got the newer dizzy, so i dont think would be it but i'll double check to see if its loose.
my car is completly stock. oh and is there any way to check and see if the dizzy shot besides replacing it. thanx for the help
