Old 06-22-2005, 10:40 AM
ryanb4614 ryanb4614 is offline
Send a message via AIM to ryanb4614
trouble starting
Well i have spent alot of money already trying to figure out why it wont start. I am trying to sell it but it wont sell if it wont start right up:
1997 chevy blazer 2 door LS 104,000 miles....
Put in a new start
Got a new battery
Fuel Filter
Put in new spark Plugs
when i was putting in the spark plugs i noticed my y pipe was crushed so i pieced it... sound better little faster pick u p now but still having trouble to start...
I go to start it turning the key and it just sounds like its going to start but it wont click over... by the 3rd time it then click over all the time... this is only if it sits for over an 30min-1hr... Im lost of what else it could be. If it would help i could make a recording of it starting.. Thanks
Old 06-22-2005, 01:05 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: trouble starting
check all battery conections and also check all starter conections sounds like something is loose.
Old 06-22-2005, 02:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
check fuel pressure?
Change cap and rotor?
Ignition switch?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-22-2005, 08:38 PM
going to change the cap and rotor tomarrow? how much est. to buy that? n is it hard i was told i might need a special tool?
Old 06-22-2005, 09:17 PM
BlazerLT's Avatar
AF -Advisor
only a screw driver is required to remove the cap and rotor and install the new ones.
Just remember to have the new cap sitting there as you remove the plug wires from the old one so you can immediately install the wire on the new cap's proper connection.
Old 06-22-2005, 10:17 PM
ok thanks, do u think i am better off buying the kit or buy the cap and rotor seperate? looking for the cheapest way because i want to get rid of this car.
Old 06-23-2005, 12:54 AM
BlazerLT's Avatar
AF -Advisor
cap and rotor kit
Old 06-23-2005, 03:04 PM
put in the new cap and rotor... still having trouble to start, sounds alot quiter of a start thow. Running out of ideas and money.
Old 06-24-2005, 02:28 PM
BlazerLT's Avatar
AF -Advisor
charge your battery
Check fuel pressure
Old 06-24-2005, 11:55 PM
ahh how about today i was curisous so i used jumper cables from my other car and my car started right up on the first try?
Old 06-25-2005, 12:15 AM
BlazerLT's Avatar
AF -Advisor
Your battery is shot, get a new one, charge it fully and then install it.
That or the alternator is weak.
