Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 06-22-2005, 08:38 AM
gam888 gam888 is offline
Lift gate will not open
I have a 93 Villager. When I try to open the rear lift gate, the latch will release but I am only able to move the gate about 1/2 an inch. I cannot get the mechanism to fully release the latch. I have removed the inside panel and can see the latching mechanisms and have tried to manipulate them to open the gate. I CAN pop open the glass window/hatch by key or my moving the control arm in the door. Does anyone have any clues on how I should proceed?
Thanks
Old 07-10-2005, 07:26 PM
William Jackson William Jackson is offline
Re: Lift gate will not open
Thanks
I just developed the exact same problem on the same year Villager. Absolutely baffling. Very interested in any suggestions.
Old 07-14-2005, 05:50 AM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Same here on a 97 but i found out that is the locking mechanism that needs to be lubricated and more than likely replaced cause the unlock function is not fully extending causing it to stick in the described manner.
Old 07-18-2005, 08:50 AM
ethan00 ethan00 is offline
Send a message via MSN to ethan00
Thanks
You have to replace the latch on the gate. It is pretty easy once you figure out a way to open the liftgate ( that is the tricky part. It is gonna take a lil elbow grease and ALOT of patience. I would look at scrap yards for one if you can find one that works because a new one costs about 135.00 CDN.
Old 07-22-2005, 05:26 AM
Re: Re: Lift gate will not open
to Ethan00: So how did you get it open?
Old 07-22-2005, 08:21 AM
Re: Re: Re: Lift gate will not open
Heh thats is where the tricky part comes in. Push the l;ift gate open as much as possible and take out the bolts that hold the latch on the door, they are 10 mm if i remember correctly. then you can use a screw driver and a pry bar ( and a lot of free time!) to pry and twist at the latch. If you work it a bit it will come loose just might take awhile is all.
Good luck! It will also be easier if you remove the plastic cover from inside so you dont damge it HAVE FUN!!!
Old 07-22-2005, 11:47 AM
IH8SPM's Avatar
The rear cover can be removed with the door closed but you will need an extra set of hands. Start by removing the seats so you have room to work. Remove the lower light cover they are snap on and look up you will see the latch assy. once you get the plastic off.. You can also remove the screws and then tilt the door cover 35 degrees eachway and it will soon loosen as you pull it. Look at the latch and do the turning. Good luck and post back when it works
