Old 04-20-2002, 02:00 AM
delsol210 delsol210 is offline
whats better ram or cold
I just wanted to know what would yeild more horse power AEM cold air intake or an AEM ram air intake or is there even a better brand of intakes for del sols well thanks for ur help
Old 04-20-2002, 01:13 PM
s2Ksol s2Ksol is offline
The AEM cold air intake will provide better results over the short ram due to direct air that is forced into it from the bumper. The possible problem with cold air intakes is a weather related issue. AEM has a water stopper device that you can add to prevent water, etc. from getting into the engine though. I have a cold air and it does provide great results and I haven't encountured any water related problems with it. If money is tight then you could check out www.teamdelsol.com under how to and there is a way to make a cold air intake for your sol.
www.aempower.com
Blair 95 VTEC
www.teamsolil.com
Old 04-20-2002, 02:28 PM
thanbks alot for ur help it was a question me and my dorm room buddies have been arguing over for some time thanks again
Old 04-20-2002, 05:33 PM
turboedsol turboedsol is offline
Send a message via AIM to turboedsol
Acording to super street, sport compact car and import tuner the AEM cold air is the best intake. i have heard that there are kits that will get you better hp but then you have to no what your doing. I read in Civic Duty that the ram air doesnt do much of anything.
ryan
Old 04-21-2002, 03:39 PM
just wanted to add. You could have a short ram and put a direct air ram scoop on the hood that could yield similar results, because it's direct air flow into the intake.
This requires buying the air ram and attaching it to the hood or buying a hood with a scoop already attached. This in return is more money to get the same effect as the cold air intake. Some people also use remove the lights or the aux lights on the left side where the intake is to allow for more air to travel directly to the intake. If this is done then maybe a short ram could work as equal to the cold air. Just giving you more possibilites, but I still think the cold air is the way to go.
Blair 95 VTEC
www.teamsolil.com
Old 04-22-2002, 01:53 AM
thanks alot for ur help
Old 04-25-2002, 07:24 AM
delsolguy's Avatar
delsolguy delsolguy is offline
Send a message via AIM to delsolguy
Another intake to consider is the Comptech Icebox if you have a DOHC.
1997 del Sol VTEC
Basic Mods completed. Dreaming of a set of cams...
