Old 06-22-2005, 08:24 AM
Zeiss's Avatar
Zeiss Zeiss is offline
Warning to me about twin turbos
Hi guys, I recently called a guy who collects stealths, and was told not to get one if I intend on driving it because of the bad trannys and synchros, amongst other things. He said i would end up spending so much money it wouldnt be worth it and I should just go for the regular R/Ts
Thoughts on this?
Old 06-22-2005, 08:43 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Warning to me about twin turbos
Bunk. Can the cars be expensive to fix if something goes wrong? Yes. But if you care for them then you will be in great shape. If you have to fix the synchros, then so be it, they are not that much compared to a lot of things. If you only make enough money to just squeek by with bills then no dont get one as you need to have a little reserve for just in case things.
Old 06-22-2005, 09:27 AM
Zeiss's Avatar
ah well, maybe I will just buy the cheaper N/A and put a Ripp SC on it only problem is the site doesnt give a link for the stealth dohc and I think they may be still working on the headers.
Old 06-22-2005, 09:58 AM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
They are just like ne other car if u use'em and abuse'em they will break. But if take car of them and reward urself with the occasional drop of the clutch or stomp on the throttle u will be good.Just my 2 cents.
Old 06-22-2005, 11:32 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
If you were gonna buy the N/A and SC it then you might as well buy the TT. More than likely you'll run into more problems w/ a SC N/A than the stock TT. Like everyone already said, if you take good care of it, it'll take care of you. The tranny's aren't bad, the synchro's are common of going bad, but if you know how to shift this won't be a problem.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 06-22-2005, 11:59 AM
Wischmaster's Avatar
Wischmaster Wischmaster is offline
Aye to that.
Old 06-22-2005, 12:09 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Its all been said pretty well. Its a more expensive car which usually entails more expensive to repair, but the frequency of repairs is directly related to how well the car is maintained.
Resistance Is Futile (If < 1ohm)
Old 06-22-2005, 01:11 PM
sLADe781 sLADe781 is offline
REALLY? How so? Because I was planning to SC my N/A sometime in the future.....so you're saying just sell my N/A and buy a TT? What problems?
Old 06-22-2005, 03:31 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
www.3sxperformance.com for long tube headers.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 06-22-2005, 06:39 PM
Zeiss's Avatar
I too am confused of how the SC would be worse for an N/A then the TT and its problems. Especially the Ripp SC
Old 06-22-2005, 07:36 PM
Stealthee's Avatar
Re: Re: Warning to me about twin turbos
Lets see. A stock TT is AWD, so no FWD tire spin, a stock TT comes stock with boost so the ECU can already handle it, a TT comes with lower compression pistons so you can run more boost. Thats just the simplistic way about it. You will not be as strong or fast as a stock TT. Turbos are more effecient than superchargers.
Old 06-22-2005, 09:55 PM
Hotshot8792 Hotshot8792 is offline
If you already have the N/A, then go ahead and supercharge it if you want. Basically, if your debating to whether or not buy a TT or buy an N/A then supercharge it, you might as well just buy the TT because it'll hold up to the power much better. Remember, the more power your making, the more of a chance it has of breaking. There shouldnt be anything wrong with S/C'ing your N/A, just make sure you take all the precautionary mods that go with it
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-23-2005, 07:04 AM
Zeiss's Avatar
uh well SCs are much more efficient then turbos, and they last longer. No need for intercoolers, no waiting for them to spool up. The list goes on.
Old 06-23-2005, 11:58 AM
The best I've seen from Ripp was like 276 WHP or something of the sort. I have never, ever, ever... seen a high HP SC'd 3/S. However... I have read of 800-1000HP 3/S that are turbo'd. I would have to disagree with the efficiency portion of superchargers on our cars. The only good ones are roots blowers on big blocks, but that's not what we are talking about.
Old 06-23-2005, 12:12 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
No, No, yes, and how bout that list???
SCs are LESS efficient than turbos because a supercharger is belt-driven. That is it takes power from the engine to actually run the supercharger, therefore you get what's normally referred to as parasitic loss. Turbochargers do not require engine power to run them: they simply run off exhaust gases, basically the waste of an engine.
Why no need for intercoolers? where do you get that? Superchargers push or pull (however you wanna look at it) air into the engine (just like a turbocharger), and that air will remain ambient temperature unless you cool it. of course, if you cool the air charge, the air will be more dense and thus increasing the air volume... couple that with increased fuel flow and you will get more hp. If you don't want to run an intercooler, then some people cool the air charge with alcohol or methanol.
True, the spool time for Superchargers is much less than that for Turbochargers....BUT superchargers are belt-driven and the only way to increase the boost on an SC is by changing the pulley that drives the supercharger. To change (increase) the boost on a turbocharger you SIMPLY adjust a boost controller (manual or electric). Turning a knob or pushing a button is much easier and simpler than changing a whole pulley, not to imagine the time you would spend changing the pulley.
and the list goes on, huh? i'd be interested to see the other ways in which people think superchargers are better than turbochargers.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
