Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 06-22-2005, 07:15 AM
fishhead65 fishhead65 is offline
AC recharge help
AC on my 2000 Montana has gone warm, don't see any obvious leaks. My friend has the coolant cylinder and says I just need to get the right attachment nozzle.
I see a port in the AC line right behind the radiator, front/center of the engine compartment. Is this the right place to re-charge? Is there a "low side" charge port? Should I put any "leak stop" product in first?
thanks
Old 06-28-2005, 08:45 PM
don14026 don14026 is offline
Ac
I have a '01 Montana that the AC got warm last year. The dealership quoted me $1000+ to fix.
From what you have said, you are in the same boat. The problem is the condensor is cracked along the bottom so adding a sealant and recharging yourself won't fix the problem. Sorry for the bad news.
Old 06-29-2005, 07:04 AM
Re: Ac
well, I re-charged 6 days ago and have been using the AC very heavy since. So far the pressure is still between 40-45psi and the air is cold. We'll see how long it lasts.
Is the cracked condenser something thats easy to see from underneath the car?
Old 07-18-2005, 03:12 PM
Cobber's Avatar
Cobber Cobber is offline
Re: Re: Ac
This is something I think we all would like to know
Old 07-18-2005, 03:21 PM
Mine turned out to be a leaky condenser. There was an obvious wet oily spot on the lower left hand side of the unit. Had to be replaced for $600. I guess its very labor intensive to get the radiator out along with the condenser.
Old 07-18-2005, 09:30 PM
GregA's Avatar
GregA GregA is offline
Re: AC recharge help
Mine was about $700.
If anyone wants to see where the leak was, click on the links below. The first one has the story and pictures when the problem was first detected, and the second has the final resolution, including before & after pictures.
AC Condenser Leak Detected
AC Condenser Replaced
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 07-19-2005, 07:10 AM
Thanks GregA! So I'm not the only one! Another reason why I can't see myself buying another GM minivan again!
