Old 06-22-2005, 02:57 AM
bl1tzk1213g bl1tzk1213g is offline
time for 6 bolt?
I experience clutch getting stuck on the floor. When i start the engine cold, i heard a grinding sound then goes away after u start it. The end play is around quarter of an inch.
If i were to fix it, do i have to just change the block with a 6bolt/1g block? I kno theres some modification needed to do that but can i just put a whole 1g engine and use 1g ECU?
thanks! btw im new here, i got '97 eclipse GS-T
Old 06-22-2005, 12:06 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: time for 6 bolt?
quarter inch, holy shit! Odds are the block and crank are ruined with that much play.
I wouldnt do a 1g ECU, I would just do the swap the usual way. You'll just have to do the baro wire mod to get around the potential RM CELs, which requires an AFC and logger.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-22-2005, 02:25 PM
ahh... so grab a 6bolt block and do some modifications for the water pump and mounting? That problem might be the wiring. Is it hard to swap 1g block? What is the problem with using the 1g ecu im just curious.
Old 06-22-2005, 03:34 PM
AF - Advisor
This is all pretty well documented on www.magnusmotorsports.com and www.roadraceengineering.com. The only modification required is a cut in the drivers side motor mount to clear the 1g water pump, and the wiring for the 1g CAS. The 1g CAS in turn can cause Random Misfire CELs and a corresponding limp mode, which is taken care of by the baro wire mod as seen on magnus site. An AFC is required to get the airflow signal back in line.
Swapping to the 1g ECU would probably require swapping over all the other sensors as well, and the wiring harness/ECU connectors are very different. Hardly worth the effort. Also, in states that do emissions testing, having a non-OBD2 ecu in the car would pose a slight problem
Kevin Jewer
Old 06-22-2005, 03:57 PM
ok. i kno about swapping 6bolt block but my dad has been telling me this.
"Just get 1g motor + ecu and install it." Hes telling me to just get a 1g JDM 4g63 with its ECU and install it instead of swapping blocks. Can u please enlighten me why this is not or is possible.
Old 06-22-2005, 04:31 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Re: time for 6 bolt?
you would be surprised... i had a 1/4 in of play when my 7 bolt went i have jake to testify for that....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 06-22-2005, 05:23 PM
AF - Advisor
Installing the 1g ECU will require rewiring the harness using 1g ECU connectors. You simply can not plug a 1g ECU into a 2g car. Anything can be done, the question is why go through ridiculous amounts of effort to reinvent the wheel when this swap has been done the right way hundreds of times and has been well documented for your viewning pleasure?
Kevin Jewer
Old 06-22-2005, 06:09 PM
engineman100 engineman100 is offline
Send a message via MSN to engineman100 Send a message via Yahoo to engineman100
do not be afraid of the 7 bolt when it is fixed right it will give you trouble free service, talk to mark at www.overbore.com
Old 06-22-2005, 10:40 PM
yea i've read about overbore but im kinda short in budget lol ='/.
$2400 + ur old engine. Im trying to fix it with minimal amount of money and effort hehe.
