Old 06-22-2005, 02:10 AM
thinmints thinmints is offline
96 xj how can i make it run cooler?
I have a 96 xj with 140K on it i was wanting to know if there is anything in the aftermarket that i can put on it to have it run cooler Bigger fan blades? any ideas would be great
Old 06-22-2005, 05:51 PM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
Re: 96 xj how can i make it run cooler?
Run cooler? What temp does it run at now? Anything between 195 and 210 is normal for these inline 6's!
Old 06-23-2005, 02:46 AM
Re: Re: 96 xj how can i make it run cooler?
it runs about 200-210 but when im at a light and the ac is runing it will get over the red line
Old 06-23-2005, 02:13 PM
Then it sounds like your aux fan isnt kicking on. Also your fan clutch is probably bad.
Old 06-24-2005, 12:27 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Re: Re: 96 xj how can i make it run cooler?
On a 96...I have 97...
Do you have an electric fan...?
Then check the fan...the fuse...and then the sensor.
Check the fan by hot wire...+ and - .....
Check the fuse the usual way..
Jump the sensor wires to see if the fan works.
Old 06-24-2005, 02:22 AM
Fan is running........ kicks on when it gets hot but seems to take longer to get the temp back to normal range
Old 06-24-2005, 12:44 PM
Fan clutch on your mechaical fan.
