Old 06-22-2005, 12:37 AM
ridinglow ridinglow is offline
Shaving door handles
can some one please give me step-by-step directions on how to shve the door handles with the weld-in filler plate! PLEASE!!!!.........THANKS A BUNCH!
Old 06-22-2005, 02:25 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Shaving door handles
weld the corners, let cool, weld down the short side, then the other, then go half way on the top, and do the other half on the bottum, then finish it, use either a mig or tig welder, grind it nice n smooth, take your time, if you cant weld/dont know, dont try it
Old 06-22-2005, 09:54 AM
OverBoardProject OverBoardProject is offline
Banned
Take handle off.
Then I would use a tube of that body panel epoxy. Then there is no chance of warping the work, and then you'll never have any rust problems there.
The next day, use bondo, sand prime and paint.
The biggest secret to that job is keep everything clean. Use only a light coat of bondo.
Invest in quality products.
Old 06-22-2005, 08:02 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
im looking to do the same thing. when i get to that point, i will tack weld it in a few spots. when you run a full weld, it will warp the thin sheet metal.tack it in the corners and maybe top,bottom, left right centers. then bondo.if you can put the plate a little behind the opening, this way its set back, the feather in the bondo. and yes, if you cant weld or use bondo, dont do it.
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
