Old 06-21-2005, 11:45 PM
3000ridah 3000ridah is offline
Clutch Replacement Help
Hey has anyone on here.. or anyone on here know anyone who's changed out their clutch?? im about to take on the complicated task this comming Sat.. i already got my hanes manual.. and some people to help.. but nobodys done a front wheel drive vehicle. hmm what will i need besides the (( clutch/pressure plate, and alignment tool )) do i need any special gasket? grease/oil.. everything i may incounter.. pleaseeeee help and let me know anything you can.. (( how long might it take?? )) thanks for any help you may be able to provide!!
Johnny D
Old 06-21-2005, 11:46 PM
Re: Clutch Replacement Help
If you have done this yourself or helped someone.. please email me at [email protected].. thanks
Old 06-22-2005, 12:04 AM
CHRIST75 CHRIST75 is offline
I just had my car a couple of months and it came with a new clutch already but the other guys may be able to help.
Hey i didn't know Hanes made manuals for our cars, i would have tried them, but well now i have an original mitsu manual 92-96 .
Where did you find that Hanes ?
Chris.
Old 06-22-2005, 12:14 AM
privatebean privatebean is offline
Send a message via AIM to privatebean
try this...
http://www.stealth316.com/2-trany.htm
Old 06-22-2005, 12:48 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Yeah i've done it a few times, it's easy. Buy some 75W-90 gear oil for when you're done. Other than what comes in the clutch kit, you may want some all purpose hi-temp grease, you're supposed to grease the splines of the clutch and the inside of the release bearing (you should have a new one of these as well), but if you use too much then you'll ruin the clutch. I didn't use any grease the last time I did it, which was a few weeks ago (and a few months ago), I didn't use any grease. But my release bearing is plastic so it has no chance of making any noise, as opposed to metal which would need a small amount of grease to prevent squealing. I've cut my time for the whole job down to about 3 1/2 hours by myself.
Oh yeah, make sure you go get your flywheel resurfaced, it doesn't cost much and can save you a lot of trouble (by a lot of trouble I mean having to take the tranny off 3 more times as I did trying to figure out why my new clutch was slipping). If you have any questions just ask, I can more than likely answer them.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 06-22-2005, 01:16 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: Clutch Replacement Help
YES! as Twizted said, it is VERY IMPORTANT that you get your flywheel resurfaced. (just take it to a tranny shop, it won't be but about 20-30 bucks). if you don't resurface your flywheel, then it will wear the clutch down really fast. the flywheel surface must be flat so as to accept the flat surface of the clutch. of one of these isn't flat (flywheel), then bye-bye clutch.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-22-2005, 08:45 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Re: Clutch Replacement Help
What Haynes manual do you have?? They didnt make one for Stealths/3000gts.
Old 06-22-2005, 12:24 PM
Sorry, its not a " Hanes " its chilton import repair manual. it breaks it down pretty good. although it has 6-10 other imports included in the book
Old 06-22-2005, 07:21 PM
Linebckr49's Avatar
is this what you have??? http://www.themotorbookstore.com/import.html
93 3000GT base
Old 06-24-2005, 11:10 AM
yeah thats it.. its as close as your gonna get to a hanes manual..
Old 06-24-2005, 11:33 AM
hey thanks privatebean for the link and Twizted_3KGT for the Advice.... im gonna do the clutch swap tomarrow.. and i'll let you all know how it goes.... thanks agian
Old 06-24-2005, 05:18 PM
Linebckr49's Avatar
3000ridah--> do you happen to have the 3si manual on CD?? i'd be curious as to the differences of the manual CD and this Import Manual. I kinda think the manual CD is more specific...but perhaps the Import Manual has a lot of diagrams and step-by-step procedures for everything like Hanes/Chilton
93 3000GT base
Old 06-25-2005, 12:24 PM
yess i have the CD aswell.. but i found the chilton manual more helpful..
Old 07-26-2005, 10:02 AM
hey thanks privatebean and Twizted_3KGT .. we did the clutch replacement that weekend and it was around 6 hrs.. ( none of us had ever done it) the hardest part was linning up the tranny.. anyways.. the link worked out great
Old 07-26-2005, 08:38 PM
cool, glad to help, hows it drive?
