Idle Problem
My car normally idles at 1000 rpm...but I first noticed when I turn my air on it drops a little bit, between 500 and 1000...but now i found something new. This happened twice in the past few weeks, when i start my car it starts up normal then drops to about 500 rpm ( happened both times when i was going to back up) then it stalls and when i restart it again it just stalls out, it will do this to or three times then drives like normal... Why???
Re: Idle Problem
check to make sure your MAS is plugged in. if this is not plugged in (that is if some mechanic forgot to plug it back in) then it will cause your idle to fluctuate btw 1500-500 rpms then die. the MAS is the computer control unit just after the air filter.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: Re: Idle Problem
You probably need to look at stealth316.com on info for the IAC. When you turn the air on the idle is supposed to INCREASE not decrease. MOst likely your IAC is gunked up or not functioning.
Re: Idle Problem
I have this same problem with dropping idle after the ac is on so what exactly is an IAC?
1995 3000GT SL (RED) My mods: Custom true dual exhaust with x pipe K&N FIPK 17 inch forged aluminum billet rims from WELD EVO
IAC=Idle air control. Its toward the bottom of the throttle body. Check out stealth316.com and it will give you all the info you need on how to test it and/or clean it.
take out your ISC, and clean it, and put it back on. It shouldnt take long, and it seems to have help solve a lot of idling problems.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: Idle Problem
I had the same problem with my car. I had just gotten it back from the shop and it was doing that the guy at the shop turned a little screw where the air intake meets the engine. It idled a little higher but still kept jumping between 100 - 800 rpm, and stalling. When it stalled most often was after I downshifted coming to a turn and then disengaged the clutch. Does that sound like it could be the same problem?
Ya that sounds the same to me...Howd you fix it?
Re: Idle Problem
Im sorry but i dont know/remember what an ISC is either.
Re: Idle Problem
I had that problem, but I change out my spark plugs and it seemed to have gone away. The only time it drops now is when I am reving the engine but it always return back to normal.
I ended up fixing mine by just getting anew iac...well a used one from someone parting out their car...its been working fine except in the past few weeks its starting to act up again, but weel see what happens
