Old 06-21-2005, 06:07 PM
kelrx8-civicbeater kelrx8-civicbeater is offline
Send a message via AIM to kelrx8-civicbeater
Exclamation Revving Up When Warmed Up-lifting Pedal Helps??
I Have A 91 DX 1.5 Sedan And Have Had some issue's with the idle .so i removed the iacv cleaned it out,reset the ECU and it still revs up when fully warm out or after 15-20 min of driving.now it has only surged 3 or 4 times meaning UP & DOWN . it more revs automatically and the only way to bring it down is to put my foot under ACCEL & LIFT the PEDAL UP.
I also have no CEL on dah but on ECU I get A 3,7,14,15
I have also pulled the iacv and it brung the idle down,THREW A CEL.but one time it didnt do anyhing.
also i have checked for vac.leaks and nothing so far.
any suggestions on what i could of forgot
oh yeah tps unplugged made no changes
thanks
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
Maido ST5 20x9 & 20x10
toyo proxes
Old 06-21-2005, 06:19 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Revving Up When Warmed Up-lifting Pedal Helps??
If pulling the pedal helps, double check or idle screw and the throttle cable - the throttle cable maybe too tight and not letting it go back to idle.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 06-21-2005, 06:42 PM
thanks for the help, I was thinking the same thing but doubted myself.looks like all the vaacum hose's have been changed not that long ago.so i am assuming last summer the previous owner had similar problems.
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
toyo proxes
Old 06-21-2005, 06:49 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
i agree with 4g4d, sounds like the throttle cable is too tight, or its binding. look to see if theres a kink in the cable anywhere
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-21-2005, 07:07 PM
oh yeah guys
when i cleaned the iacv there was no screen on either round holes ?does this matter
Old 06-21-2005, 07:27 PM
EF You's Avatar
EF Life Giver
no it doesnt
Old 06-22-2005, 03:43 PM
KinkBykr's Avatar
KinkBykr KinkBykr is offline
Send a message via AIM to KinkBykr Send a message via Yahoo to KinkBykr
I had the same problem with my CRX dx, so I prayed the throttle cable at the trottle body and it went away, I wasn't getting any codes though, it was only the throttle cable
Old 06-23-2005, 12:46 AM
thanks guys im still checking and will check
the throttle cable again.hope thats it
worst case I can pull the iacv off my hatch but then my girl is gonna have to deal with it
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
toyo proxes
Old 06-23-2005, 02:37 PM
KinkBykr's Avatar
Re: Re: Revving Up When Warmed Up-lifting Pedal Helps??
WAIT! mine started doing it again, not as bad though. I shouldn't have said anything. I guess I am going to have to actually do something with it too.
Old 06-23-2005, 07:16 PM
dagoEF's Avatar
dagoEF dagoEF is offline
I had a similar prob with my stock motor where the throttle pedal wouldnt go all the way up. I ended up figuring out that the spring on the throttle body got weak, I just removed it and trimmed about 1/2" or so off it, bent the end so it would hook to the body and it worked. It made the pedal come all the way up so I didn't have to pull it up with my foot. I hope that makes some sense
Old 06-24-2005, 12:48 AM
somewhat
im starting to think my iacv might not be screwed up and maybe the throttle cable or spring.I Know im gonna jinx it now but so far so good.
thanks for any input guys
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
toyo proxes
Old 06-28-2005, 05:04 PM
well its back
and Im convinced its the Iacv now since when I unplug it drops rpm.so time for a new one or ebay one.sucks hope its doesnt start acting up when im doing my inspection tommorow
thanks guys for all the help
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
toyo proxes
