Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-21-2005, 02:56 PM
tonesdman tonesdman is offline
Need expert help on troubleshooting
I have a 94 1st gen. non turbo talon. My car has a bad idle, the car runs good above 1200rpm but when you go low it misses. No trouble codes are displayed.
Story:
The oil plug worked it's way out of the engine and oil pumped all over my exhaust. I plugged it with a bolt to long and locked the oil pump gear. "Big mess" The timiming belt shredded. So i replaced the timming belt and oil gear belt. I also check all my valves and suprisingly they are great.
. These are the things ive checked:
timing "good"
vacuum "good"
idle speed motor "good"
idle switch "good"
mass air - did a ohm check seemed O.K. but i wish their was a way to test i further
egr "blocked off anyway"
O2 sensor - again Ohm test worked out O.K.
fuel pressure "great"
leak down test "good"
compression test "great
Base idle set screw - bypasses computer and set it up right.
ECU looked ok
I am from Toronto Canada and i can't find anyone out here who really knows a dsm. Anything that you can think of please feel free to post. Thanks guys!
Old 07-05-2005, 09:30 AM
Anybody??????????????????????
Old 07-12-2005, 02:29 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Need expert help on troubleshooting
how do you know your timing is good? the timing has to be damn near dead on perfect for them to run right. 1 tooth off could fuck the whole motor.
95 Talon TSI AWD
97 Eclipse GST
Old 07-12-2005, 04:45 PM
I rebuilt the timing belt and i can guaranty it dead on
Old 07-13-2005, 12:18 AM
what i don't get is how a longer bolt locked up the oil pump. the oil pump gear isn't anywhere inside the pan and the closest thing the bolt could fuck up is the crank or rods but it would have to be like 9 inches long for that to happen.
95 Talon TSI AWD
97 Eclipse GST
Old 07-13-2005, 08:55 PM
macder macder is offline
Send a message via MSN to macder
If everything that you mentioned is in working order, then you probably have a simple ignition problem. Try replacing your spark plugs, and ignition wires.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 08-02-2005, 09:43 AM
rs97eclipse1695's Avatar
rs97eclipse1695 rs97eclipse1695 is offline
Send a message via AIM to rs97eclipse1695
yeah check your plugs and wires...or any other ignition components
2008 Eclipse GT
-Sun Sound and Leather Package
-BONE stock
1997 Mitsubishi Eclipse RS
-Cold Air with K&N
-Stainless 4-2-1 Header
-2.5" Catback
http://www.cardomain.com/ride/3012565
Old 08-02-2005, 09:44 AM
2008 Eclipse GT
-BONE stock
-Cold Air with K&N
-2.5" Catback
Old 07-25-2006, 04:31 PM
dellaswope dellaswope is offline
have a 95 eagle talon non turbo fwd auto transmission. it won't always shift down, whatz up with it?
Old 07-25-2006, 06:59 PM
SLoe's Avatar
SLoe SLoe is offline
http://www.albinoblacksheep.com/flash/posting.php
Watch this! Start a new thread with an appropriate title, and don't post in year old threads that don't have anything to do with what you are asking.
AND be more specific about your problem.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-25-2006, 11:10 PM
kjewer1 kjewer1 is offline
AF - Advisor
There are a limited number of things that can shred the timing belt. Two things come to mind off the top of my head as I sit here at work ready to flip the fuck out.
Putting longer bolts on the two oil pan bolts under the tbelt will shred the belt. The factory uses two bolts that are slightly shorter for this reason. I don't know what that has to do with the "oil plug," whatever that is supposed to be.
There is a plug on the back of the block where you insert a screw driver to check the position of the rear balance shaft belt. If this is where you put in a longer bolt, and you have the balance shafts, that would stop the rear shaft and therefore oil pump from turning, and since the oil pump sprocket can't turn, you would damage the belt.
The description leaves me scratching my head and wondering what the fuck is going on, but it's likely that it will end up to be one of these two things.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-26-2006, 12:20 AM
Kevin, this thread is over a year old.
95 Talon TSI AWD
97 Eclipse GST
Old 07-26-2006, 03:15 AM
AF - Advisor
Holy fuckin shit, are you kidding me? Oh well, not my fault. I get in the question answering zone and stop looking at petty details. You act like I didn't just break 800 PMs tonight... (802)
Kevin Jewer
Old 07-26-2006, 05:38 AM
firesdoom's Avatar
firesdoom firesdoom is offline
Send a message via AIM to firesdoom Send a message via Yahoo to firesdoom
Your transmission doesn't know what your throttle is doing. It could be either your throttle position sensor is malfunctioning or your throttle valve is clogged or malfunctioning in some other way. I'd check the TPS first.
Oh yeah, and start a new topic!
Black 92(6 bolt) Eclipse Auto N/T 2.0
K & N Air Filter, Megan Racing Strut Bars, 2.25 Mandrel Bent Catback, Unorthodox crank pulley, EGR block off plate, No balance shafts, KYB AGX struts and shocks, two piston GSX calipers
1990 AWD Astro Van
Don't mod a car with problems. Don't swap parts without testing them.
