Old 06-21-2005, 03:24 PM
alerolemon alerolemon is offline
Help Me
I bought my 2000 alero last june. It has treated me good untill this spring. When the snow was melting my dash lite up in lights. My Abs light came on which I think triggers my service vehicle soon light and trac off lights to come on. It only did this when it was melting outside. As time has gone on it has gotten worse. My low trac light comes on when ever i move my stering wheel, even if the car is in park. But lately my abs comes on as soon as i start my car which shuts my traction control off. I have been reading some other peoples comments and it sounds like it could be abs sensors or the ECBM. Can someone help me please?
Old 06-22-2005, 07:46 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Help Me
The key is to determine which wheel sensor is causing your problem. They're located on the wheel bearing hub assembly. Another thing is check the wiring going to each sensor. The wiring routes down through the lower control arm direct to the sensor. Good luck!
Timeslip 08/12/06
AF Community Guidelines
Old 06-22-2005, 07:33 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help Me
bnaylor3400 gave you good advice. Should take care of the problem once you find out which sensor is bad.
