HELP! injector tuning problem
alright heres the deal, i have some 750cc injectors for my sr20 but i know my car wil need to be tuned when i put them on, would a SAFC work? or will i need to do something else, any info would be great, i would like to have my sr20 runing again soon
thanks, austin |
Re: HELP! injector tuning problem
yeah, it will work... i rather get a full stand alone dough.. that unit cost about $300 right? a F-con Vpro cost about $800. or if u want a stand alone W some map in it (fcon has no stock map, ie the car will not start when the unit is installed, u need to take it to a dyno)
a stand a lone with a stock map, AEM, Apexi .... SR w 750cc ??? why?? please don't tell me that u have the stock T25 turbo? and if not what Turbo r u running? why so much fuel? do u have enough air to go with the fuel? 550 cc is good enough... unless ur boosting like 1.5 Kpas Injectors will NOT give u ANY hp!!! unless u RAISE THE FUEL AIR MIX... u know, u still need to take it to the dyno, if u play w the unit and mess around, u could blow up ur motor. i don't know bro, but a stand alone is well worth it. and a 750 cc injectors are over doing it..
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
BTW i have a HKS f-con V-pro (tuned by BLAST) and a HKS GT2535 turbine... i still have the stock injectors.. boosting 0.9 bar MORE THEN ENOUGH SPEEED!
Can you get a blank PowerFC? Like for the KA. (I doubt the PFC has stock KA-T maps. lol)
no lol, it has the SR20DEt map in it, u can erase it dough...
the most a safc can correct is a injector that is 50% larger then stock. so with a stock 370cc x 1.5 = 555cc injectors. so if you run 740cc's then its too much for the safc to handle. it will run rich all the time.
303whp stock internal KA-T 94 Acura NSX Best E.T. 13.559 Best Trap speed 107.62 mph |
Re: Re: HELP! injector tuning problem
Motec > F-Con Pro >AEM >Haltec >Power FC> AFC |
Re: Re: Re: HELP! injector tuning problem
F-con is the shiite yo.. (yay!)
i don't know, but the people at BLAST say that tunning a Fcon is a pain in the but, even Xsess engr said so... may be thats why?
You guys underestimate the functionallity and budgetness of a tuned ECU. Standalones are great and everything, but tuned ECU with SAFC isn't far behind. Besides the fact that it is cheaper, you can make corrections before the change of a light. Found that out today.lol
OH, and 550cc will max out around where you need to start thinking about stronger internals. 615cc will be right about where stuff will start breaking. mynismo has a nice SR setup. Should see what he suggests...
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
