Old 06-21-2005, 01:18 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Talking Slotted/Drilled rotors
Just installed my slotted/drilled rotors. Tell me what you think
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 06-21-2005, 01:20 PM
alphalanos alphalanos is offline
looks good. what kind? how do they perform?
96 EJ6. Future home of boosted B18C1.
Old 06-21-2005, 01:22 PM
crazzyguydj's Avatar
crazzyguydj crazzyguydj is offline
Send a message via AIM to crazzyguydj
Re: Slotted/Drilled rotors
look good, when I put mine on I tried to paint them and when I sprayed them with brake cleaner the paint started running and shit it sucked. I think I tried to use caliper paint. But it didn't run on the calipers... Must be the metal
My first car! blue 93 plymouth laser 5 speed <Wrecked!>
My second car! red 93 mitsubishi eclipse 5 speed
3rd car (soon to be) Golf tdi 03 or 04 havent found one yet
Old 06-21-2005, 02:48 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Nice!! I've just ordered slotted rotors, new calipers, ceramick pads, and stainless steel braided brake lines and now I cant wait to get em after seeing yours. (Got a fine-ass discount on the whole thing!! $298)
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-21-2005, 09:19 PM
Turbodog97's Avatar
Just a Neon
Ya they are pretty awesome. I have to wait a few hundred miles though before I can try out their potential(to break 'em in) but they were relatively easy to install and look great. But I would suggest not to get the colored zinc coating though because it seems to be comming off Also...I was wonder does anybody have an OEM white spoiler for sale??? Im wanting to switch back, thanks!
05 Srt4
97 Mx-5
Old 06-21-2005, 09:27 PM
Whathits14 Whathits14 is offline
Originally Posted by endlessheart666
Also...I was wonder does anybody have an OEM white spoiler for sale??? Im wanted to switch back, thanks!
Good choice, and the rotors look great
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 06-21-2005, 11:36 PM
kjewer1 kjewer1 is offline
AF - Advisor
The zinc coating will wear off the friction surface, of course. The rotors are constantly being "machined" by the pads The point of the coating is that it remains everywhere else and prevents corrosion. Corrosion can "weld" the rotor to the hub, this will put that off a good bit longer. Still worth having it. If the holes are drilled through, as opposed to dimpled, check the rotors for cracks with each oil change.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-22-2005, 02:20 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
they look pretty tight. let us know how they perform when the break-in period is done.
95 Talon TSI AWD
97 Eclipse GST
Old 06-22-2005, 07:33 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You will absolutely love them. Mine stop on a dime, there is no fade and no shuddering. They are one of the best mods I have done to date!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-30-2005, 02:37 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
They look hot,
I'm looking to do mines soon. What brand are they? How much? Were they a bitch to put on or is it D.I.Y.?
99 Eclipse Spyder GS
Old 07-01-2005, 07:26 AM
Mine are Brembo mated with Akebono ceramic pads. You can get the rotors here:
http://turboimport.com/catalog/eclipse.htm
$239 for all 4 rotors (front and rear)
The pads you can get here:
http://www.dsmparts.com/customer/pro...&cat=13&page=1
They were $68 for the front and $68 for the rear ($136 total).
Worth every penny. Just make sure you install the rotors so they turn in the correct direction .
They were easy to do, I did a write-up on them covering the installation, I'll see if I can find the link.
Here it is:
http://www.automotiveforums.com/vbul...d.php?t=397132
1997 Spyder GS-T
5-Speed
Old 07-01-2005, 01:13 PM
toicy4ya's Avatar
Thats hot Spyderturbo,
What is the difference between cross drilled, dimpled or slotted rotors?
Old 07-02-2005, 01:47 PM
wuman82 wuman82 is offline
Cross drilled are the holes that you see on the rotors, dimpled are holes that doesn't go completely through the rotor, thus called dimples. The holes/dimples are there for better airflow, thus better cooling. One big disadvantage to having cross drilled is that if the drill job wasn't done right you can easly crack your rotors, which would not be good. Slots are the slots you see on the rotors, they are there for gas to escape, so you get a good contact between your brake pad and rotor.
98 Eclipse GS
CAI
More to come, can't be fast enough.
Old 07-02-2005, 08:47 PM
toicy4ya's Avatar
Kool,
Thanks for the feedback. So overrall which would be the best to go with?
Old 07-02-2005, 11:17 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
sloted rotors are designed to heat up the breakpads, they double function as gas extractors. the best type of gas extracting rotors are drilled/ventilated disk style.
DSM geek
