Old 06-21-2005, 12:51 PM
TiburonDelAsesino's Avatar
TiburonDelAsesino TiburonDelAsesino is offline
Question N/A Guage Question
Hey I was just wondering what the two best guages to get for a naturally aspirated car would be. So far I am thinking about oil pressure, but im not sure on the other. Also how do you read these guages like oil pressure and so on to make sure your car is running correctly? Thanks!
2003 Tiburon GT
Haydin Oil Cooler, Hotshots Racing Header, Injen SRI, Borla Exhaust, SR BBTB, NGM Stage 4 Upper/Lower Intake Manifolds, UD pullies, Apexi Grounding kit, ARK Front Strut Brace, Nology Coolwires, kspec motor mounts, greddy oil catch can, Tein pro suspension, Tein front/rear sway bars, SAFC Neo, 15mm Hub Adaptors, Invader CF hood, centerforce stage2 Clutch, Cumstom reground cams.
Old 06-21-2005, 01:16 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
you may want to get oil temp as well if you dont already have that one. Stay away from the air/fuel gauge. Its nothing but a pretty lights display that bounces back and forth. If you have the money for a wideband get that. I think they start around $350. If you dont have the money for that, than an egt is another solution.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 06-21-2005, 11:50 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: N/A Guage Question
a vacuum gauge, properly read, is a very accurate way to determend engine load and engine health. in fact, i beleave some early fuel economy gauges were just vacuum gauges
