Old 06-21-2005, 11:55 AM
KinkBykr's Avatar
KinkBykr KinkBykr is offline
Send a message via AIM to KinkBykr Send a message via Yahoo to KinkBykr
spindle nut wont budge
I am replacing my cv boots on my Rex and neither spindle nut will budge with any of my wrenches, even with a breaker bar and a pipe, haha. but it really isn't coming loose at all. I have a 91 CRX DX, so if anyone has had a similar problem it would be awsome for some knowledge to get that off.
Old 06-21-2005, 11:58 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: spindle nut wont budge
Spray it with pb blaster, knock the little retaining tab up, then put your breaker bar on it and put about a 5' good sized pipe on it, it will come loose or your not very strong, add more people if nessasary. Or put a jack under the breaker bar and jack it up, that works also.
Old 06-21-2005, 12:03 PM
KinkBykr's Avatar
I already sprayed it with PB blaster like crazy, had me, my dad, my Fiancé and about a 6' pipe and I'm a biker and my dad's got guns so we are not weak, so I'm not sure, I think I might just get out the C4, haha. but I will try the idea with the jack.
Old 06-21-2005, 09:02 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Try a simple solution, an impact wrench. GL
Old 06-21-2005, 09:32 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
i had to heat mine with a mapp torch and use a good impact
Good Luck
Steve
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 06-21-2005, 09:49 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
impact. your constant pressure with a breaker bar isnt nearly as effective as the impact hammering while turning.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-22-2005, 02:27 PM
KinkBykr's Avatar
I got it off, and I did try and impact wrench and I have to say, with my 20 gal. compressor maxed and using my huge gun, the thing didn't budge, but we got both easy with a longer pipe and pb blaster.
