Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 06-21-2005, 10:42 AM
Tha0Sand6Man Tha0Sand6Man is offline
Send a message via AIM to Tha0Sand6Man
Problem: Exel TZ-7 Rims
I just got some rims off of a guy that were supposed to bolt to my 1998 Tiburon. He said they came off an Elantra. However, when bolting them on, they dont fit flush, theres a screw in the way on the rear end in between the studs, and on the front, there are 4 hex bolts that keep it from mounting flush. Do i need spacers or what? Thanks.
Old 06-21-2005, 05:15 PM
speeddemonGtV6 speeddemonGtV6 is offline
Send a message via AIM to speeddemonGtV6
Re: Problem: Exel TZ-7 Rims
did u do any type of searching around to make sure they would fit, and did u pay for them?
WANNA RACE?
Old 06-21-2005, 10:52 PM
I got the rear wheels mounted fine, the screw was just a locator screw. These came off an Elantra with the same bolt pattern. 4x114.3 Which is the exact same car, except the body and other minor changes. As for the front, the hex bolts are still in the way.
Old 06-23-2005, 11:43 AM
hmmm take them out and see if u have any problems, should be fine if u put everything back on right and tighten it to the right amount.
WANNA RACE?
Old 06-28-2005, 02:13 PM
tibby01 tibby01 is offline
you have captive rotors.
couple things you can do:
1. convert to a non-captive setup. you should need calipers, rotors, hubs, and spindles.
2. get holes drilled out in the back of the rims for those four big bolts. NOT recommended though, can weaken the wheel.
3. get spacers and hub rings and hope they work together.
