Go Back   Automotive Forums Car Chat > Cars in General
Old 06-21-2005, 10:09 AM
D-FOSSE's Avatar
D-FOSSE D-FOSSE is offline
Send a message via Yahoo to D-FOSSE
Fiberglass paint
Im trying to paint my interior someone told me they have a fiberglass paint where you can spry it on plastic, wood, etc. and it gives it that shiny fiberglass look is this true and if so what is it and where can i find it
Old 06-22-2005, 12:01 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Are you trying to pint vinyl, like door panels, dash...headliner, etc? If so just use a dye like SEM colorcoat or VHT penitrating vinyl dye. I prefer SEM mylself.
http://www.sem.ws/category.php?category_id=36
http://72.10.43.141/penetratingcolordye.htm
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 06-22-2005, 07:17 PM
D-FOSSE's Avatar
Re: Fiberglass paint
i have already painted some things with krylon fusion but it isnt relly giving that fiberglass shine that im looking for what does the dye do
Old 06-25-2005, 02:05 AM
Honda God
Re: Re: Fiberglass paint
Well, VHT penetrates and re-dyes the surface. SEM works like a dye in the end on vinyl but is a coating. For what you want use SEM. Use SEM Colorcoat. Prep as discribed on the can. Clean plastic/vinyl first well with a good cleaner/degreaser like special cleaner concentrate. Afterwords use some wax and grease remover. I sometimes follow this by wiping with some lacquer thinner. After this prep the vinyl with vinly prep and follow the directions on the can, then you are ready to spreay the vinyl with the dye. For plastic spray with plastic prep. Then sand with 400 grit sandpaper, then clean again with a plastic prep, SEM, Dupont, etc all make plastic prep.
After this use either SEM adhesion promoter or sand free. Apply via directions on can. Then spray the colorcoat on. For a very high gloss, follow your chosen color with some SEM high gloss clear, that should give you one heck of a shine.
EPR Member 4 Life
Old 06-27-2005, 09:29 PM
hardcorejuggalo hardcorejuggalo is offline
Send a message via AIM to hardcorejuggalo
Talking
if you want that fiberglass look you gotta make the plastic smooth sand with a 150 sandpaper then use spot filler its putty used in fiberlgassin it sands nice and once you have the plastic smooth paint with the fusion it will look so good you cant tell if its dry or wet. MCL.
Its a Juggalo Thing MCL
