Old 06-21-2005, 10:04 AM
JustinCredible10 JustinCredible10 is offline
fuel injectors
Does anyone know if there's a way to test if the fuel injectors are working on a 98 2.2? I'm hoping only one has gone bad and I want to see which one it is.
Old 06-23-2005, 05:31 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
Re: fuel injectors
do you have an idea which is bad. or for that matter how do you know it is bad.
Old 06-23-2005, 06:12 PM
No I don't know which one is bad. If I did, I wouldn't be asking how to check. Also, I've checked every other component of the fuel system so I'm sure it's an injector problem.
Old 06-24-2005, 10:36 AM
Random Hero Random Hero is offline
Re: fuel injectors
Best way to check is to start the car, and with it running try loosening each injector, if its working it'll squirt gas out of the hole back at you after about a half turn or so.
Old 06-24-2005, 11:11 AM
Thanks for the idea but the problem is the car won't stay running. It's not getting enough fuel.
Old 06-24-2005, 11:23 AM
Re: fuel injectors
Well if it won't stay running then my best guess is that all of the injectors are shot, or the problem is somewhere else. It should be able to run on 3 of 4.
Old 06-24-2005, 11:26 AM
Ok, it would be a shame to have to replace them all though. They're fairly expensive. I checked all the other components though. Thanks.
Old 06-24-2005, 11:36 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: fuel injectors
why not just go to a junkyard and grab some from there? NO sense buying brand new ones
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 06-24-2005, 11:48 AM
Yeah, I'll probably do that.
Old 06-24-2005, 02:05 PM
lexxxx's Avatar
lexxxx lexxxx is offline
Re: fuel injectors
your fuel line might be gloged it has hpened to me. take the fuel line of the front and the back and blow compresed air through it then if that dosnt work try the injector problem. or the fuel pump might be going bad and its not pumping like it should. or your fuel filter might be real cloged. many things you half to check on cars to get a fix on the problem. and thats just if its the fuel lines and such. tell me more once you check all that.
NOS is like a hot girl with AIDS you wanna HIT IT but your afraid of the CONSEQUENCES
Old 06-24-2005, 03:48 PM
I've already replaced the fuel pump, fuel filter, and fuel pressure regulator. Also, I removed the fuel line from the fuel pressure regulator and turned the key to the "on" position. When I did this fuel sprayed out for a brief moment. So I don't think there's a clog. Thanks for the thoughts.
Old 06-26-2005, 03:59 PM
Banned
Re: fuel injectors
they make something like a doctor has to listen to your heart with, you know what i am talking about, they us something like that to check to see if the injectors are spraying, there is like a little ball in there or something. do you not have any check engine codes?
