Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-19-2002, 06:52 PM
somedood somedood is offline
Question what size tires are too big or will not fit on my civic?
i want to get some rims and tires for my 91 civic hatchback. i want to know if 205/45 16's are too wide. will they rub or will they be fine? any suggestions on tire setups would help me alot...thanks... :alien: :flash:
Old 04-19-2002, 07:22 PM
changedagame108 changedagame108 is offline
Don't worry, you'll be fine. How much are you lowered or are you at all?
Old 04-19-2002, 08:23 PM
im kinda low
i have max speed coil overs and kyb's in the back and tokiko's in the fron and im down all the way. but when i get those rims ill probably set them to where the tires barely hit the top of the wheel wells.. or will 205/45 16's tuck in under the wheel wells? let me know what to expect and what to do ..thanks julio :alien:
Old 04-20-2002, 12:28 AM
1993HondaCivic 1993HondaCivic is offline
offset offset offset, its all about offset
Old 04-20-2002, 09:30 PM
offset?
i dont want to look dumb ..but here goes..what do you mean by that ? explain....
Old 04-20-2002, 11:56 PM
Re: offset?
nothing dumb about learning. go here. this talks about wheel offset. if ur looking for 16", look for a rim with an offset a little higher than 40+, 40 is pushing it i would say. and no 205/45 is not too big, but if u lower it alot, get 205/40
What size tires are you guys running on the 18" wheels? Cobra4B GTRA / GTWS / GTS 10 08-09-2009 06:34 PM
What Size Tires Will Fit? heavyredchevy Ram Pickup | Ram SRT10 5 04-08-2006 01:48 PM
What size tires will fit 86 Blazer with 6 1/2" lift. NYFF395 Tires and Wheels 1 03-02-2004 09:55 AM
What size tires fit 94' SR without lifting? cutler02 Montero/Shogun/Pajero 1 02-27-2004 01:11 AM
what size tires are too big or will not fit on my civic? somedood Tires and Wheels 0 04-19-2002 06:52 PM
