Old 06-21-2005, 04:54 AM
s2pidluv4u s2pidluv4u is offline
burning smell?
...ok i got a 1995 3000gt base auto tranny...and i was on the freeway with my od off and pwr own...jus messing around with my car i decided 2 redline it a couple of times jus 2 show my friends how bad is the 3kgt on the freeway...anywaz...rite after i took the exit i did another blowout on the 3kgt flooring it 2 redline...but then i smelled some kind of burning rubber smell...it lasted onli 4 a couple of seconds...but im jus worried is there a problem with my car...i jus got the auto tranny rebuilt on my car a yr ago...is it because ive been floorin the throttle between 5rpm - 6rpm?...is it bad 2 always red line a auto 3kgt?...or somewhere similar of revving it high?...sorry im a newb...but 1 last thing...ive been hearing people tellin me not 2 use the PWR switch cuz its goin 2 messed up my tranny?...is this tru?...anywaz thats all i have 2 say 4 now...thanks...
Old 06-21-2005, 09:59 AM
Igovert500's Avatar
blue + red light magnet
Re: burning smell?
Well I wouldn't say it's bad...but it isn't good. You are driving it hard, and that puts alot more wear and tear on your engine and tranny. As for the burning smell....there are billions of things in your car that can cause that. Unless you can locate the source of the smell, or see smoke (color and location) there isn't much we can help you with.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-21-2005, 12:28 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: burning smell?
yeah...and go ahead and use your power switch it's not gonna hurt anything. But DO NOT do neutral drops (put it in neutral, rev the gas, and put it in gear to try to do a burnout). My auto worked perfectly, did 3 neutral drops, just 3, and it was done the next morning...not to mention doing the neutral drop did nothing but give a small chirp cuz it just dropped the rpms before goin into gear.
oh yeah and how fast were u going, b/c I had a set of tires that whenever i did like 80-100 mph for a few miles, i'd get out and smell burning rubber. So could just be your tires overheating.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 06-21-2005, 03:01 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: burning smell?
ya, burning smell could be a LOT of things as Igovert said. it could be the smell of brake dust from hard braking at high speeds, could be the smell of oil if you have a valve cover seal leak, could be other things too. i get a similar burning smell when i drive her hard and shift in the upper rpm band. i'm not worried. but don't redline your car, you make max power at 6000 rpm, so no need to redline to 7,000.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-21-2005, 09:30 PM
Re: burning smell?
If you redline to 7k you'll be closer to 6k (max pwr) in the next gear, that's why you redline when racing.
