Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-21-2005, 02:17 AM
want a supra want a supra is offline
Question Twin Turbo vs. Singal Turbo
What are some of the big pros and cons of running a larg singal turbo at say... 20psi, instead of having two turbos at the same psi?
Originally Posted by GForce957
Those who eat the Breakfast of Champions wear velcro sneakers
Old 06-21-2005, 06:58 AM
jcsaleen's Avatar
jcsaleen jcsaleen is offline
Re: Twin Turbo vs. Singal Turbo
Single turbo unless you need two and that pushing rediculious numbers.
1 turbo = less spool time. 2 turbos equals more lag (unless there very small = weak power or insanly expensive)
"Driving a Mazda RX7 on the track for the first time was very cool ? this is a production car that most
resembles the movement of a formula car in my experience so far.
" ~ Igor
Old 06-21-2005, 07:46 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
It's harder to get two turbos hooked up on a V engine. There are two banks and routing both exhausts into one is more difficult than having one per bank. Also the intake is harder to route through the single turbo into the manifold. Also most kits for V engines use two turbos so you'll most likely have to frabricate your own kit.
Old 06-21-2005, 11:54 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
20 psi of a single turbo and 2 of the same turbos making 20 psi combined will yield no extra hp hense the reason most supra owners convert twin turbos to single turbos. Twin turbos are more of a "pimp factor" imho.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 06-21-2005, 04:11 PM
jcsaleen's Avatar
True they also do it with FD's
" ~ Igor
Old 06-21-2005, 06:26 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Esp since there are single turbos capable of pushing 3000HP.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 06-21-2005, 07:50 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Re: Twin Turbo vs. Singal Turbo
NOT TRUE!! My car made 3612whp on a mustang dyno on pump gas. So they can make much more than that even.
(I was using a TD04 15g w/ the 5th injector set up for fuel management.)
I hope you guys know i'm kidding
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 06-21-2005, 08:08 PM
now what about a larg turbo at say again 20 psi and, a smaller turbo making the same psi?
Old 06-21-2005, 09:27 PM
jcsaleen's Avatar
Your just going to have more lag lol. Is this a test or something?
" ~ Igor
Old 06-21-2005, 09:43 PM
240SX Guy
Larger compressors flow more air at the same pressure.
Big turbo=higher airflow
small turbo=lower airflow
So on a smaller turbo, you will need to run more boost to obtain the same airflow as a larger turbo at lower boost. And with more boost on the smaller turbo, you get more heat.
So in many cases, a larger turbo is also more efficient given you stay within the proper airflow range.
CODE NAME:"RUSSIAN RED"
lol
-Cory
12.6@122mph
Old 06-21-2005, 09:45 PM
jcsaleen's Avatar
Hahaha omg thats rediculous!
" ~ Igor
Old 06-21-2005, 10:11 PM
Re: Re: Re: Twin Turbo vs. Singal Turbo
No i just want to know more about turbos.
Old 06-21-2005, 11:41 PM
240SX Guy
The stickies at the top of this forum are a good place to start. There is an article discussing this very subject....
-Cory
12.6@122mph
Old 06-22-2005, 02:06 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
I'd prefer a single
Twin turbos to me are better with BIGGER engines.
two doesn't mean more power because your exhaust has to give enough flow to spin 2 turbos.
....It has been a LONG time...I want to move to FL or Japan.....
Old 06-22-2005, 07:07 AM
having one small turbo and one large turbo is what is called a sequential turbo system. a sequential turbo system has virtually no lag but is heavy and is very complicated to setup because you need to have cutoffs and everything for both turbos. now with ball bearings the advantages of a sequential setup have been eliminated.
