Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 06-21-2005, 12:53 AM
ShlemJDM ShlemJDM is offline
Send a message via AIM to ShlemJDM
H22 Vs K20 ?
Which one is Better to own Are They Both Hard To Install Which One Is Easyer ? Are you gotta take out A/c From Both of em ? or Just H22 ?
Old 06-21-2005, 01:26 AM
sivic02's Avatar
sivic02 sivic02 is offline
Re: H22 Vs K20 ?
You might want to try being a little more specific in exactly what motors/car your talking about. Also sentence structure makes reading much easier.
Oh, and the search button can be your friend.
Here's to being single, seeing double, and sleeping triple
Old 06-21-2005, 01:35 AM
97integrals's Avatar
97integrals 97integrals is offline
Re: Re: H22 Vs K20 ?
Old 06-21-2005, 08:32 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: H22 Vs K20 ?
The K20 out of the RSX Type S is probably a little better than the H22, but it really depends on what kind of car its going in, what type of budget you have, and what you plan to do to the engine.
Be more specific....it'll help you get the answers you're looking for.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 06-21-2005, 01:26 PM
Sorry For Not Be Spacific.
My Quastion Is Which One Is Better For Ek Hatch Civic I Know That K20 Is More Expencive But H22 Is Harder To Put In. Just In Your Opinion Which Motor Will U Pick Between Those 2?
Old 06-21-2005, 07:27 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
If money isn't a problem you should put the KA20. The power guys are getting out of those with basic bolt-ons is awsome. It is also lighter than the H22. The swap is easy because there are kits to do it. I personally like the H22 better, and the b-series motors better than the H22, but I'm like one of those muscle heads that hasn't figured out that the new motors today get just as much power, are lighter, smaller, and get better gas mialage, except I'm an old Honda head. B-series from start to finish all the way. It also helps when you have four friends who all run low 12's with about 200whp NA in eg hatches. I will be mid to high 12's with my 4-door eg.
Old 06-21-2005, 09:59 PM
sivic02's Avatar
Re: H22 Vs K20 ?
I dont know if the h22 is harder to put in, but I do know the k sure as hell wont be a breeze. Dont forget about axels, motor mounts, wiring harness, etc.
Personally I would go with the k but I am extremely biased. I am a k series engine whore.
Old 06-22-2005, 09:37 AM
Dose Any One In Here Knows If i will pick K seriese How Much Will Total Come Out In $$$$$$$$ ill install it my selfe but motor and all the axels mounts this all will cost me
Old 06-22-2005, 01:23 PM
sivic02's Avatar
Re: H22 Vs K20 ?
www.hybrid-racing.com
They have some really high quality stuff.
Motor mounts $599
Wiring harness $350
Axels (400whp) $700
= $1649
The price of the engine will really depend on where you get it from. Some go for around $5000 for engine, tranny, ecu. Or a couple months ago i could have gotten you a k24a2 motor (no tranny) for $2000. It all depends on when and where you get it. If the motor doesnt come with an ecu expect to toss out about $1500 for a new hondata k-pro(you should get it anyway). You also have shift cables, fuel lines, header, custom exhaust piping....
Hell by the time your done you could have just bought a brand new civic hx.
Honestly though, I dont think you will want to drop a k in your car yourself. Not to be rude or anything but you dont sound like you are very knowledgable about swaps and this isnt a swap for a first timer. I am not trying to talk you out of it or anything, if you really want to do it and have the garage for it then go for it, but just consider the cost and intense labor involved with it first.
Old 06-22-2005, 01:53 PM
S13wanabe's Avatar
Yeah it sounds like you are planning on doing this yourself. Just get an estimate from a reputable shop that you can get everything from. That makes it easy and they might cut you a deal since you would be getting everything from them. Or put the same money into a b-series motor and the 2 swaps you are talking about wouldn't be able to touch you. B-series swaps are very easy, and if you are in Southern California I can hook you up with a guy to build your motor for pretty cheap and you will run 12's, NA. NA all the way. If Honda motors were meant to be turboed then Honda would have done it.
Old 06-22-2005, 02:39 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
H22 = Bitch to put in.
K20 = Bitch to put in.
You'll need mounts, axles...and the like, for both swaps.
Its really a matter of which one you can afford. They will perform very similarly (in drag, at least.)
If you can afford it, go for the K20. There are a lot of benefits to it (such as weight), as opposed to the H22. (And this is coming from an H22 owner.)
Into an EK Hatch, a B-Series would probably be the most cost effective out of all.
