Go Back   Automotive Forums Car Chat > Mazda > MX-3
Old 06-20-2005, 11:36 PM
mazdaspeed19 mazdaspeed19 is offline
Send a message via AIM to mazdaspeed19 Send a message via MSN to mazdaspeed19 Send a message via Yahoo to mazdaspeed19
tranny
can you run a stock k8 tranny on a klze motor...or is that just not cool.....if so is it a good idea or no....wat are some good mods for a klze thanx
Old 06-22-2005, 03:22 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: tranny
you need a new tranny, some mods are for the klze are,
igntion system
plugs/wires
turbo
cAi
headers
cat back
high flow cat
65mm throttle body
underdrive pulley
ecu upgrade
that's just bolt ons.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 06-23-2005, 07:22 AM
mx3man's Avatar
mx3man mx3man is offline
Send a message via MSN to mx3man
Re: Re: tranny
igntion system
plugs/wires
turbo
cAi
headers
cat back
high flow cat
65mm throttle body
underdrive pulley
ecu upgrade
I love forums for misinformation... Seems everyone talks without knowing. You DO NOT need to change your transmission. There is no transmission for the K-series which is stronger than any other. The MX6 tranny is the only different one, and this is because it has a 4.11 Final Drive ratio instead of the normal 4.388 on the K8 (1.8L V6 that came in the MX3)
