Old 06-20-2005, 11:34 PM
drumboy722 drumboy722 is offline
High Idle and rough shifting
here is the problem. I start my 2000 grand am and the idle speed is at about 1100 rpm, and it won't calm down at all. when I put it into gear, and whem it shifts gears, it does so very rough. a local shop told me that my throttle position sensor was bad and that would take care of the idle, but couldn't gaurentee that it would take care of the shifting problem. Any more ideas for me?
Old 06-21-2005, 12:01 AM
jay02's Avatar
jay02 jay02 is offline
this sounds the same as the problem i'm having... but my idle goes down after a few minutes... regardless it seems to shift hard everytime...
so i'm with you on this one.. no suggestions as of yet..
96 Grand Am SE
No Mods
Old 06-21-2005, 04:32 AM
Knifeblade Knifeblade is offline
Re: High Idle and rough shifting
I thinking if the idle can be tamed, the shifting may be easier.
Old 06-21-2005, 08:27 PM
grs7 grs7 is offline
I have the same with a 2001 with 2.4lt. Will aslso watch for an answer.
Old 06-21-2005, 09:44 PM
A few thoughts, guys, IAC {idle air control], Throttle body gunked, TPS is dirty, MAF sensor, clogged injectors [one of the most neglected parts of the engine]
Old 06-22-2005, 07:57 AM
good news, I found the answer for the idle and rough shifting
good news, I took my car to the shop, and I was having the rough shifting and high idle speed, and they told me that my throttle position sensor was bad, or acting up. so for about 150 dollars they replaced the part, and my car seems to be running fine. they also told me it wasn't a bad idea to get my tranny fluid flushed. good luck guys and let me know if it works out for you.
Old 06-25-2005, 04:33 PM
Did it work?
