Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-20-2005, 09:34 PM
stuckey_fun stuckey_fun is offline
Unhappy 95 Pontiac Temp Actuator Mode
Do I have to remove the air bag to actually replace this? If so do you know how to deactive the airbag? Does the dashboard have to come out?
Old 06-21-2005, 05:59 AM
markwb's Avatar
markwb markwb is offline
Re: 95 Pontiac Temp Actuator Mode
Stuckey, You can disable the airbag by locating and removing the SIR fuse. (not sure of location on '95 bonne) I'm not quite understanding the temp. actuator mode though, what is it?
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 06-24-2005, 05:29 PM
sellncars's Avatar
sellncars sellncars is offline
Send a message via AIM to sellncars Send a message via Yahoo to sellncars
Are you talking about the blend air door actuator? This actuator is for the hot/cold switch. if this is the one, just take out the glove box insert and you can see it right from that hole. There will be a threaded rod hooked up to a plastic clip, To test this actuator,unhook the rod from the clip and see if the temp goes from hot to cold. If it does the actuator is bad.
Good luck,
Sellncars
1999 Chevy Malibu, 3100V6 VIN J with 73,000.
1997 GMC K1500 EXT cab, 350 Vortec with 164,000
