Old 06-20-2005, 09:15 PM
Mikes71Cam Mikes71Cam is offline
71 Camaro
485 Horsepower 383 stroker motor, 4 bolt main block. Cast steel Scat 3.750 crankshaft. Hypereutectic pistons, 10.3 CR. 5.7" 4340 I-beam rods. AFR SBC Street 195 cc aluminum heads. Hydraulic roller cam & lifters. Clevite 77 bearings. Moly rings. Roller tip rocker arms. Chromemoly push rods. Melling roller timing set. Melling oil pump, drive and pick up. Milodon oil pan. Gold timing cover. Felpro and Detroit gaskets used. ARP performance bolts used throughout. OEM style balancer. SFI flexplate.
Should i turbo or go with the more expensive Supercharger?
This is for racing so a supercharger would get me off the line way faster ever tho im pushing out 460 torque or go with turbo for longer street racing?
Mikes71Cam.
Old 06-20-2005, 09:29 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: 71 Camaro
is this going in the 71 camaro?
i would probably say turbo as long as you have space and sufficient cooling system. Superchargers apparently have a pretty limited amount of boost because their rpm is dependent on engine rpm. plus you can rev to 5000-6000rpm on the line to get the turbo pressure up and then run max boost all the way down the track assuming your driveline is in order.
My knowledge of force induction is limited though. But nice setup. Sounds like slicks and wheelie bar is in order.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-20-2005, 09:36 PM
Re: 71 Camaro
I dont need wheelie bars on it yet because no cops know what it runs and its a classic so no inspections. It doesnt jump bad the front tires dont hop off the ground cause i never floor it off the line. But thnx for the reply.
Mikes71Cam.
Old 06-20-2005, 09:39 PM
Re: 71 Camaro Picture
I'm trying to get my pic on my profile but i dont know how lol. im not the best with computers.
If you could tell me how to id apreciate it.
Mikes71Cam.
Old 06-20-2005, 09:42 PM
Re: 71 Camaro
well you said its for the races, so you might want heavy throttle off the line... and you want to add a charger... that will defintely get the wheels off the ground. If you want to win... bars and slicks are coming your way.
Old 06-20-2005, 10:34 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 71 Camaro
turbochargers have been superior to superchargers for several years now, if you are serious about max speed, go turbo, a complete system made by someone who knows what they are doing will get you off the line faster, and provide more averate torque than a supercharger. Although centrifical superchargers have been known to make more peak hp than turbos, the hp curve is very peaky, rather than flat like a turbos curve is. For all practical purposes roots style superchargers are dead and buried.
although i have a question, when you talked about bustin your buddies balls in the prelude, you said you had like 537hp, here you are saying you have only 485hp, are you talking about two different engines??? im confused.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-21-2005, 03:57 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Re: Re: 71 Camaro
Originally Posted by 89IROC&RS
...although i have a question, when you talked about bustin your buddies balls in the prelude, you said you had like 537hp, here you are saying you have only 485hp, are you talking about two different engines??? im confused.
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 06-22-2005, 09:15 PM
FireFox05's Avatar
FireFox05 FireFox05 is offline
Send a message via MSN to FireFox05
Re: 71 Camaro
Third confused person, enlighten.
1998 GTP sedan
Mods:MPS 3.4|180Tstat|PowrTuned|AL104's|SSAC's|DIY HAI|F-body's|GMPP H.K.|Gen2 SSC|KYB GR-2|Hand e-brake|Bucket Rear Seats
Soon:Appearance mods|some secret stuff|Audio stuff
Future: 12 second DD
