Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 06-20-2005, 08:49 PM
budster2 budster2 is offline
Question 94 Accord front brakes
I am thinking about changing the front pads on my 94 Accord. Any idea where in can get detailed info -step by step- on how to do this? thanks
Old 06-21-2005, 12:29 AM
BullShifter's Avatar
Re: 94 Accord front brakes
its very simple to change the pads, but to resurface the rotors or replace is a whole different story.
Remove wheel
Remove lower caliper bolt(14mm or 12mm)
Pivot caliper up
Remove pads
Compress caliper
Lube new pads
Push caliper in towards car until it pops off - lube that slide and the other still in the lower caliper
Reverse to install
******MAKE SURE TO PUMP THE BRAKES WITH THE KEY OFF BEFORE DRIVING*******DONT APPLY EXTREME PRESSURE TO REDUCE CHANCE OF OLD PARTS LETTING GO*******
Use Honda brake pads
