Old 06-20-2005, 08:02 PM
ColoradoSilverado ColoradoSilverado is offline
Serious vibration at 10-15 mph
I have some serious vibration at 10-15 mph, It was always there but relly lightly now it's getting really bad. At first I thought it was the front rotors but it's both when accelerating and braking. Anyone has an idea what it could be ?
Bert
Old 06-20-2005, 08:08 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: Serious vibration at 10-15 mph
Check your u-joints, make sure the lugs are tight and have your tires balnced. Good place to start.
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 06-20-2005, 08:27 PM
red00lght's Avatar
red00lght red00lght is offline
I just had this problem. I replaced the center bearing in the driveshaft (my 99 4.8 2wd has a two-piece) and that cured almost all my vibration. I have also put in lowering-shackles so I think I need some pinion shims as I still have a little bit of vibs going through 10-20mph. U-joints may be the problem as well with yours....mine were ok...
Old 06-20-2005, 08:37 PM
Pardon my dumb question, u joints, those are the ones that connect the drive shafts right ?
Old 06-20-2005, 09:22 PM
jethro_3's Avatar
As long as you are trying to learn, not a dumb question. A u-joint looks like an X with the caps on the end that have needle bearings inside connecting two parts of the driveline. They allow the parts to angle off of straight letting the axle travel. With blocks around the wheels, BOTH SIDES, and the truck in neutral, get underneath and try to spin the driveline. If it has play at the u-joint, get it replaced. Play would be defined as a short distance that causes the driveline to jerk when going one direction to the other not a solid movement. If you have a carrier bearing, circle around the whole shaft, check it for play also. Thanks for reminding me red00lght.
Old 07-01-2005, 09:32 PM
Well, I finaly had some time today to get under the truck and check some things. I checked all the U-joints wich are all fine, no play at all. I took off all wheels and checked for play , also checked all the brakes, also all fine. I found out that one of my rear shocks was bend badly so I replaced both (did was not the problem). I looked at all the ball joints wich are also fine. Now I also have a constant humming at 50-55 mph, if I go faster it disappears, but that vibration at 10 mph is very annoying. Anyone has any suggestions ?
Bert
Old 07-02-2005, 09:24 AM
JCL82 JCL82 is offline
I'm reading my silverado book and it says this
If the vibrations occurs at the same engine speed(rpm) regardless of which gear the transmission is in , the driveshaft is NOT at fault since the driveshaft speed varies.
Is the truck 4WD ?
55 Shudder or vibration during acceleration
1.excessive toe-in have alignment checked
2.Incorrect spring heights
3.worn or damaged inboard or outboard cv joints
4.sticking or inboard cv joint assembly
Old 07-02-2005, 11:34 AM
Is the truck 4WD ?
Yes, the truck is 4WD. That vibration is only at 10 mph so it's only in first gear, don't think there's a way to check it at the same speed in second gear. And it's both in accelrating and braking.
Bert
Old 07-02-2005, 02:52 PM
You ever thought about trying one of the other gears ? 1,2,3 gea
Old 07-02-2005, 05:45 PM
How do I go 10mph in second or third gear ? Maybe I forgot to mention that it's a automatic.
Bert
Old 07-03-2005, 09:14 AM
draboo's Avatar
draboo draboo is offline
I think I understand what you are talking about. You cant do 10 mph in second. The trans wont shift out of first because you are doing only 10 mph.
Can you tell which end or corner of the truck the humming/vibration is coming from?
Try a few sharp turns at the 10-15 mph speed and see if it gets worse.
I m not a mechanic by any means,but I suspect a wheel bearing may be the culprit.
Old 07-03-2005, 03:46 PM
It's the right front corner, I will spend some more time on the truck tomorrow and see if I can find something. I'll keep you guys posted on my findings. if it's a wheel bearing I should here it when I jack up that corner and spin the wheel by hand ?
Bert
Old 07-09-2005, 06:21 PM
Well, got the wheels balanced today, that did the trick on the vibration/humming at 50mph but the 10mph vibration is still there. And they put it on the lift and checked the driveshafts and concluded they are fine. Anyone has any suggestions ?
Bert
Old 07-14-2005, 09:15 AM
orpha orpha is offline
try part #89060582 intermediate steering shaft. my 2002 with 85k gets replaced every 30k...put your truck on incline, shift from drive to reverse several times while softly touching brake. you will feel steering grab.
another screw up from gm
Old 07-15-2005, 05:30 PM
Re: Re: Serious vibration at 10-15 mph
Is this a part # from GMpartsdirect ? I tried the shifting thing but don't feel the steering "grab" as you mentioned. Also, after having the front wheels balanced I said the vibration at 50 mph was gone, yes for 6 days it was now it's back and even worse from 50 to 70 mph. Is there another way to check the intermediate driveshaft ?
Bert
