Old 06-20-2005, 07:24 PM
javelin1 javelin1 is offline
Question 74 javelin engine
I have a 74 javelin bodys about done but need help with engine and drivetrain car runs ok 130,000 miles has a 360 should it be rebuilt or is there a new engine I could use I was seeing a crate 360 magnum will this fit and if so what about the trans and rear end not very sure on these motors any help would be helpful
Old 06-21-2005, 05:43 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 74 javelin engine
The 360 Magnum engine is a Chrysler "LA" block (originally designed in the mid-1960's). It is completely different from your AMC engine and will not fit your car, unless you make extensive custom engine mounts wiring driveshaft etc and use a Chrysler trans.
Your 360 is an AMC block originally designed by Nash in the mid-50's. (Nash and Hudson joined to form AMC in 1954).
IMHO rebuild your 360, or look for an AMC 390 or 401 which will bolt right in.
Old 06-27-2005, 09:45 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Rebuild it. Put in some higher-compression pistons, a good cam, and a 4-barrel and intake and have some fun whuppin' up on about anything around, that's a strong motor once the compression is up and it's fed properly
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
