Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-20-2005, 06:24 PM
robcaryh robcaryh is offline
Airbag blinking code 46? 2002 Ranger
Great,another thing that just started,of course about 7 weeks after my 3 year warranty expired.
My airbag light on the dash is blinking a code 46. Any idea what that means or is it something simple that can be fixed? I dont even want to know what an airbag repair would cost.
Old 06-20-2005, 07:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Airbag blinking code 46? 2002 Ranger
Check owners manual for warranty information. Look for Supplemental restraint Systems. I believe some of these are warranted for more than the 3/36. It may be ina separate warranty booklet. Check there first. Your code indicated the drivers seat belt pretensioner has been detected as faulty. The first thing to do is inspect all wiring going to the pre-tensioner. If all wiring is good, the pre-tensioner needs replaced. The system needs to be de-activated before any tests are done. Refer to owners ,manual fuse locations to remove correct fuses to disable the system. If you have removed the proper 2 fuses, the air bag light will stay on constantly for more than 30 seconds. They are in the fuse panel under the dash.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-03-2005, 09:40 PM
Davinicus Davinicus is offline
Had the same code. It was the "Airbag Disabled" Lamp below the AC controls was burned out. Went to radio shack and picked up a bulb for 1.99 and soldered it in.
