Old 06-20-2005, 04:09 PM
robcaryh robcaryh is offline
97 Grand Am blows fuse everytime i blow the horn
Another strange problem with my car that just started up in the last few weeks. Everytime i blow the horn,the 15A horn fuse blows and needs to be replaced. Any bright ideas with this one?
Old 06-20-2005, 10:20 PM
Hoags's Avatar
Hoags Hoags is offline
Re: 97 Grand Am blows fuse everytime i blow the horn
Some how you have developed a short in the wiring at or near the horn, everytime you hit the horn there is contact to a bare wire which is causing the fuse to blow. Unfortunatly I am not familiar with the removal of the horn/airbag assembly that will allow you to track down the culprit.
Hope this helped, good luck.
Old 06-21-2005, 11:44 AM
kallenbach_05 kallenbach_05 is offline
the same thing happened in my 97 so i just put a 20A fuse in and it fixd it for now.
Old 06-21-2005, 06:52 PM
Knifeblade Knifeblade is offline
There is one other possible, the horn itself could have shorted out. Check by unplugging it, and run a+ and- lead off the battery to the horn terminals themselves, see if horn sounds healthy.
If so, then prob. is farther up, either a bare wire, or drain at the horn relay [which, sorry, not sure where the relay is located].
Old 06-21-2005, 07:53 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
I would agree with Knifeblade.
If you have some spare fuses, unplug both horns and see if the fuse blows. If the fuse doesn't blow than one of your horns is shorted. Pkug one horn in and try again if the fuse blows than is your problem horn. If the fuse doesn't blow unplug the first horn and plug in the other horn. Fuse blows that's your problem.
The contact in the steering wheel is a ground circuit that provides a ground side path for your relay. This is a very little chance for a short there.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 06-21-2005, 09:47 PM
Thanks flat, I should have texted hornS, there are two of them.
Old 06-22-2005, 09:44 PM
Hoags's Avatar
I forgot to ask...Do you happen to have the radio controls on the steering wheel?
