anyone with a 90-92 TPI
i am trying to pass a smog check and i continue to fail. I purchased new vacuum lines to replace the broken one that went b/t the EGR solenoid / valve.
i tried to use this link to help me put it together right http://www.chevythunder.com/fuel%20i...um%20lines.htm but, i think i put them on backwards at the EGR solenoid. btw i have high hydrocarbons and NOx but low enough carbon monoxide. i was told that the ignition / timing could cause the HC to be high, and the EGR sys not working properly can cause the NOx to be high. i just put in a new O2 sensor and cat just before the test and also the new vac lines in the EGR system but still failed. so what i need is someone with an intact 90-92 TPI to check the vac lines on their EGR system and plz tell me if mine are backward. in the picture the solenoid has a red marking on it and the left vac line goes to the EGR valve and the right one goes to the TB http://img.photobucket.com/albums/v3.../100_00401.jpg
Re: anyone with a 90-92 TPI
It looks like your vacuum lines are connected right. The EGR is probably stuck closed due to carbon build up. The only way to correct this is to either remove the EGR and clean it so the valve opens and closes freely (not always possible) or replace it.
As you must know it's under the plenum, and takes a little work to get at. |
