Old 06-20-2005, 02:55 PM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
Question RE: Oil covered sparks plugs????
I have an '89 civic hatchback, 1.5l d15b2, 5 spd, and lately I have noticed that the car seems hard to start in the mornings and it needs a bit of gas to get started. I checked the computer and it shows code 16 (faulty fuel injector). I check the injectors and they didn't seem to be loose, plus I run 91 octane gas and fuel injector cleaner though it all of the time. But after seeing the error code, I replaced my spark plugs to find 2 of them covered in oil. What is causing this and how serious is this???
"If you can read this...I'm Parked!..............Or broke down."
Old 06-20-2005, 03:42 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: RE: Oil covered sparks plugs????
thinkin valve cover gasket set...the full set with the gaskets for the sparkplugs
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-20-2005, 05:47 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Yeah could be the gromets like blue said, or leaking valve seals. Witch end had oil of it? Also just because it isnt loose and you run 91 octain and injector cleaner though it doenst mean anything, could still be bad, alot of those injector cleaners do absolutly nothing.
Also... what does the RE: in the title mean?
Old 06-20-2005, 08:54 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
what you failed to realize is a code 16 although it is a injector code doesnt always mean loose connection. it could also mean clogged crack or broken injector. so keep it in mind. as for the oil covered spark plugs well your burning oil and you probably need to clean the fuel system.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 06-27-2005, 11:09 PM
my crap car (damn civics)
The past few days the car has been running ok. But I worry that I might lose ol' besty. When the engine is cold, it almost stalls at the first time I apply the brakes. It is after stalling, but not so much now. As for the oil on the plug, it was on both sides, including the wires, and the car doesn't burn any oil or smoke from what little exhaust I have. (LOL). Thanks for the advice about the
Old 06-28-2005, 05:01 PM
kelrx8-civicbeater kelrx8-civicbeater is offline
Send a message via AIM to kelrx8-civicbeater
get a gasket set from napa
its like 22 bucks and a easy fix.2 of my plugs were
completely drowned in oil.
pull the spark plug wire out,stick your finger in hole and touch the black grommet.if its brittle and breaks like crumbs then you found the culprit.
also have you reset the ecu,to clear all previous codes ?
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
Maido ST5 20x9 & 20x10
toyo proxes
Old 06-29-2005, 10:12 PM
skotman's Avatar
skotman skotman is offline
i had the same problem. it was the valve cover gaskets for me. pretty easy to replace. i lost one of those stupid nuts on the top of my valve cover, though... and then i found it 6 months later lodged between the radiator and the fan shroud. i was happy to have found it.
easy fix.
my old ones had remnants of that Renew crap all over it, and everything was as hard as a rock.
