Old 06-20-2005, 01:39 PM
KPot2004 KPot2004 is offline
Need Help Camaro Running Like Crap
Well I have had my camaro on the road like 2 weeks now then all of the sudden yesterday when i got in it to leave it sounds like its running ok but soon as I put it into gear it starts idleing really rough, and when i try to drive the tach is jumping all over the place, and when i am on the gas it starts backfiring. while this is happening the tachs jumping all over and its to the point where its about to quit
replaced: wires cap and rotor
oh, its a 1992 rs with the 5.0 tbi
Old 06-20-2005, 02:03 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Need Help Camaro Running Like Crap
may be an ignition control module.
however i suggets you run the car for error codes, this should give you the best lead to solve the problem than any guess work we could offer.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-20-2005, 02:16 PM
yeah... i fixed it, still not suyre what it was, just tapped up a bunch of wires that I could see that were loose
Old 06-20-2005, 02:49 PM
Mikes71Cam Mikes71Cam is offline
Cam Running Crappy
Check all your wiring to your engine and your electrical housing for anything that may be loose for the tach screwing up but for the backfiring you should replace sparkplugs and see how it acts after that, your spark plugs may be too small so the firing would be off.
Old 06-20-2005, 07:27 PM
wow, shity car day today, i thought I had it fixed and i go to get some gas, well on the way there, all of the gauges start going all over the place and the service engine soon light keeps flashing on and off, so right as I pull into the 7-11 it quits, and when i try to restart it the started wont even click on at all
so yeah..... kinda shity day for me
Old 06-20-2005, 07:37 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Yeah it does sound like your ignition control module, if you DID get a new one then make sure the cap is on correctly because if you put it on incorrectly the gauges will jump and your maro will sound like its puttering, atleast mine did, RPMs were going crazy.
Old 06-20-2005, 08:39 PM
ct91rs ct91rs is offline
what gauges were acting up? the only gauge that should be affected by the distributer is the tach. if a bunch were irratic you probably have a problem with a ground
Old 06-20-2005, 09:58 PM
the speedo and the tach were both jumping all over, well i got out my test light and there is no power to the purple wire on the starter when the key is on and off ,and when the key is turned on 1 dash light is on even when the light switch is not on, but its dark and i dont feel like working on it anymore, i hate electrical problems so god awful bad
Old 06-20-2005, 10:43 PM
89IROC&RS's Avatar
shorted wire harness, 100% sure. go back to where you saw those wires that you tapped on that fixed it. and inspect that bunch of wires very carfully one at a time, ill almost guarantee that youll find one where the insulation was rubbed off and its shorting either among each other, or to ground, causing those problems.
Old 06-21-2005, 08:56 AM
on a side note i got a new hood, i only paid 185 for it, supposedly one side was flared out a little by where u bolt it on but i didnt notice anything and it went on without any problems
http://img91.echo.cx/img91/6342/picture0850tw.jpg
http://img91.echo.cx/img91/2935/picture0866zw.jpg
http://img91.echo.cx/img91/5680/picture0885vf.jpg
http://img91.echo.cx/img91/7834/picture0895sg.jpg
http://img91.echo.cx/img91/6027/picture0903es.jpg
http://img91.echo.cx/img91/7160/picture0915jv.jpg
http://img91.echo.cx/img91/9529/picture0924ii.jpg
now i just have to get rid of the rust on the drivers door
Old 06-21-2005, 09:04 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
looks like its hung a little of to the right but thats sweet, i wanna get a 4 inch cowl hood but i dont have the money, i just love the cowl hoods, always have , always will. do you have a jeep cause i think your dors to it are leaning against the garage in that pic, lol that awesome. my aunt wouldnt let me take her jeeps doors off.
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 06-21-2005, 07:36 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
where did you get that hood from? did they have to ship it to you?... cause I need one just like it. 2.25" cowl right?
cheapest i have found is $199 from a company in Cali, but they need $250 for shipping and they build to order so it takes 6 weeks to get it.
Help me.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-21-2005, 09:22 PM
http://motors.search.ebay.com/_W0QQsassZshermanparts
thats where i got it from, just keep checking there are 82-92 camaro hoods on there off and on but usually at least every other week. mostly they sell damaged goodmark stuff, it was an hour drive from my house so i didnt have to pay for shiping.
pretty good day today though i got some black tape and taped up all the wires and got them looking really good, well as i am doing this i see a ground wire just laying there so i tighten that up and the camaro fires right up
Old 06-21-2005, 09:24 PM
oh yeah, i need help setting the timing to i know its supposed to be set at 0 degrees but i cant find the wire i am supposed to disconnect
Old 06-21-2005, 10:17 PM
Is eating.
I want a cowl too, probably a 3 or 4. That cowl hood looks awesome on your maro btw. somehow breathers dont look good on third gens.
