Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 06-20-2005, 01:19 PM
partywemust101 partywemust101 is offline
bornco 2 wont start
i just replacved the transmission in my 89 bronco 2. it was running before i pulled the bad tranny. after i hooked everything back up my bronco would try to turn over but would not start i just replaced the starter and it is doing the exact same thing. what do i do?
Old 06-20-2005, 02:50 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: bornco 2 wont start
check all of your grounds. Sounds to me like you forgot to tighten a ground wire.
Old 06-20-2005, 06:35 PM
all grounds are tight with new starter,battery,and starter silinoid
Old 06-22-2005, 09:06 PM
Truck Truck is offline
There are a ton of grounds...look for the ones from the engine to the bay, and everything in-between. You wouldn't be the first to skip over a wire, or seven.
Old 06-22-2005, 11:18 PM
lobbdude lobbdude is offline
quick basic diagnostics
it doesnt have to take a long time, but start with some basic disgnostics.
- Got fuel pressure to the engine?
- Got spark?
- spark hitting at right time?
start from the top and you could save yourself a lot of time tracing down a simple problem.
Good luck
