Old 06-20-2005, 09:55 AM
4G63t Power 4G63t Power is offline
Locked Transfer Case
OK I am posting again about my tranny. Its a quick question. I think my tansfer case locked up, but can it just unlock? My tires locked up on the highway doing 75. It still rolls but like I said in another post it feels like the clutch is slipping when its in gear and it makes a grinding noise. I jacked up the car and when I rotate the back tire/s, the fronts rotate too like there supposed too. If my transfer case had locked up or I broke something inside it the wheels would not spin freely and smoothly like they do, would they? There is no grinding noise when I rotate the wheels or anything so I dont know.
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 06-20-2005, 09:56 AM
Re: Locked Transfer Case
Also real quick. If it did lock, there is a recall on them. Who do I take it to get the new t-case?
AWD sold
New car*
90' Eclipse Gs-T
Ported 2g manifold
Slowboy racing UICP
SAFC
1/4=13.7 at 109
Old 06-20-2005, 04:58 PM
kjewer1 kjewer1 is offline
AF - Advisor
The tcase is probably the problem. This has happened to many poeple (Some didnt survive). I think its likely enough to be the tcase that you should tow it to a dealer and tell them the story. They should replace it under recall. If they try to tell you that the seal was already replaced "under recall" fight that to the end. Its the number one trick they use to get out of this. The NTSB/NHSA requires them to cover all SAFETY recalls. They need to replace the entire tcase, AND the yoke on the driveshaft that is also part of the recall. IF they dont change this, it will still leak and eventually lockup, and the worn yoke will also damage the sleeve on the new tcase. They have to both be replaced at the same time.
Hope that helps. Good luck with it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
