Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-20-2005, 09:57 AM
dave404 dave404 is offline
stalls,backfires until warm.............
posted this on a previous post, has anyone with similar problem found solution ?
have had this problem stalling until warm up for a while.
when i 1st start it, it runs a few seconds then dies. start again and idles rough, finally idle smooths out, but if i try to drive it until warmed up good, it backfires through engine. once warmed up it runs good.
checked all hoses and fittings , no vaccum leaks.
replaced IAC.
plugs and wires ok.
Old 06-21-2005, 04:28 PM
fbi-interceptor fbi-interceptor is offline
Send a message via Yahoo to fbi-interceptor
Re: stalls,backfires until warm.............
i can just about guarantee i know what your problem is. http://spydermagazine.com/2002/March.../maf_clean.htm. goto this website and follow the instructions. this will take under 10 minutes and will solve your problem
[/IMG]
Old 06-24-2005, 11:35 AM
jase386 jase386 is offline
Send a message via AIM to jase386
our GM had the same problem. Sent to the shop they said the throttle body needed to be cleaned. But started shortly after a fill-up, but lasted thru 3 tanks of gas. we arent sure if we got water in the gas or what, but it stopped its problem shortly before going to the shop. could just be a bad run of gas in yours too
