Old 06-20-2005, 04:18 AM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
I Need Help With Iac Sensor!!!!
I got a B18B swap. The only code my car is throwing now is 14 (Intake Air Control). I went to the local performance shop and got a used one and installed it and it did no good. Does anyone know what the voltage should be accros the 2 wires on the plug. I know for a fact its the right plug i already researched that.
Someone told me the ECU could be bad but how do i find this out? I dont know anyone with a 94 teg. I really need to get my car running right, it bucks at RPM range of 1200 - 3000.
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 06-20-2005, 07:25 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: I Need Help With Iac Sensor!!!!
The EACV plug is similar to another one. You sure you got them hooked up correctly?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-20-2005, 09:39 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
Also you may want to reset your ecu if you havent already it will sometime continue reading a code after you fix the problem
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
