Old 06-20-2005, 03:51 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Another tensioner qestion...
Is the tensioner wheel supposed to wobble? My 98LT is sqeaking pretty bad and I know it's from the belt area but I can't pin down where. I backed off the tensioner and the only pulley that had any play was the tensioner. Is this normal or should it be a nice smooth bearing type roll?
Old 06-20-2005, 07:37 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Another tensioner qestion...
the tensioner arm should move back and forth, but the pully itself should have a smooth spin to it. If it doesn't replace it. It's actually cheaper to replace the entire tensioner instead of just the pully.
Old 06-20-2005, 03:52 PM
The spring is fine but the pulley has a wobble (feels loose) when I spin it by hand.
Old 06-22-2005, 06:42 PM
How hard is it to replace? I see it only has one bolt. Will I need to preload the spring first or is it a direct bolt on?
Old 06-22-2005, 06:56 PM
rlith's Avatar
direct bolt on, just remember though, it's reverse thread, so clockwise to loosen
Old 06-23-2005, 03:50 AM
Alright! Thanks for mentioning that! It would have drove me nuts...
Old 06-23-2005, 09:43 AM
tom3 tom3 is offline
If that is a steel pulley, you can usually just press out the bearing and replace it for about 8 bucks. If plastic, replace the whole thing.
Old 06-23-2005, 03:02 PM
IS the bearing a regular item at the auto stores?
Old 06-23-2005, 03:29 PM
About any NAPA dealer will have about any bearing. Not so sure about the others, or any supply place should carry them, pretty standard bearing in it.
