Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-20-2005, 01:31 AM
bighops2000 bighops2000 is offline
Send a message via AIM to bighops2000 Send a message via Yahoo to bighops2000
Very poor acceleration
My rodeo does not accelerate worth a crap. i have a 3.2v6 and i know it should accelerate much better than it does. i have changed the oil, and fuel filters and i have used the lucas fuel injector cleaner. my after market filter is less than a year old. i almost feel like the tranny is leaving b/c it takes so long the get up. would a tranny flush help. what could be the problem
Old 06-20-2005, 09:51 AM
rodeo02 rodeo02 is offline
Are you sure you are starting off in 1st gear? If the trans is in limp mode, you will typically start off in 3rd, which will give a sluggish take-off. Put the floor shifter in 1st & shift manually to see if thier is a change.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-20-2005, 10:27 AM
Re: Very poor acceleration
G/luck
Joel
its an automatic 2wd
Old 06-20-2005, 12:16 PM
Re: Re: Very poor acceleration
Yep, I assumed that since you asked about a trans "flush". Can't really flush a manual trans. Try what I suggested. Shift your automatic manually to see if there is a performance change.
G/luck
Joel
Old 06-21-2005, 01:30 PM
Re: Re: Re: Very poor acceleration
G/luck
Joel
i tried and it was a little different maybe only becuase i was looking for something bvut it seems like it was picking up faster whats the casues of that.
Old 06-21-2005, 11:57 PM
Re: Re: Re: Re: Very poor acceleration
When you put it in "D", you may not be starting out in 1st gear, but 2nd or 3rd instead. This could be a faulty "winter" mode switch, a bad range/mode sensor, or an internal transmission problem.
G/luck
Joel
Old 06-26-2005, 01:37 AM
tranny flush did the trick WOO HOO!
