Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 06-20-2005, 12:45 AM
2002Drew's Avatar
2002Drew 2002Drew is offline
Send a message via AIM to 2002Drew
GT vs. GTS
I'm sure this gets asked a thousand times, but my gf wants an eclipse, and i was wondering what the differences are between the GT and GTS.
dance...the night away
Old 06-20-2005, 07:19 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: GT vs. GTS
10hp and about $3000.
the GTS has a better intake manifold than the GT which gives it the 10 extra HP. it also has different wheels(same wheels just different color).
Old 06-20-2005, 07:35 AM
cficare68's Avatar
cficare68 cficare68 is offline
Re: GT vs. GTS
Yep thats about it. Well and of course the additional letter on the back of the car
Old 06-20-2005, 10:55 AM
2002EclipseRS's Avatar
2002EclipseRS 2002EclipseRS is offline
hey, eclipsed4utoo, Were you in Myrtle Beach last week? I was there and I swear i saw your car. Same red color, same wheels, clear corners. Just wondering if it was you.
Made the switch from Mitsubishi -> Honda (acura)....so glad i did!
Old 06-20-2005, 11:51 AM
Re: GT vs. GTS
i was there on Sunday the 12th. me and my g/f
Old 06-20-2005, 12:32 PM
Black Knight 00's Avatar
Black Knight 00 Black Knight 00 is offline
Send a message via AIM to Black Knight 00
Re: GT vs. GTS
and you cant get gts without leather
Old 06-20-2005, 12:47 PM
evil6remlin evil6remlin is offline
Re: GT vs. GTS
The GTS also has a higher compression ratio than the GT. GTS 10:1 GT 9:1. So if you have any plans down the road for FI short of a full rebuild, I would go with the GT as its more capable of handling boost on stock internals. And if you get the GT you can always swap over the GTS plenum if you find one ( then you have the best of both worlds).
Old 06-20-2005, 12:55 PM
Re: GT vs. GTS
i dont know how i forgot about the higher compression since weve been talking about it over at club3g
Old 06-21-2005, 03:03 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: GT vs. GTS
one last thing..............4 wheel disc brakes for the gts.
....It has been a LONG time...I want to move to FL or Japan.....
Old 06-21-2005, 07:45 AM
Re: Re: GT vs. GTS
the GT has that also
Old 06-21-2005, 07:57 AM
Re: GT vs. GTS
Also if you are willing to buy and find a 2000 GT with low enough miles for you, you can find one that has Fed Spec emissions equipment. This means that there is only one main cat instead of the later models which have one main cat and two precats. I believe I read somewhere that the Fed spec GT's dynoed even higher than the new GTS's due to having less restriction in the exhaust flow. Also, 2000 GT's have dual piston brake calipers up front instead of the single piston calipers the later years received.
Old 06-21-2005, 08:16 AM
Re: Re: GT vs. GTS
yup
Old 06-21-2005, 10:38 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: GT vs. GTS
the GTS is a GT w/ all the options 6-disc cd changer, alloy fuel door, leather, etc. and it has the extra hp and higher compression, but my car has an intake and it was faster than some other guy's GTS so its nothing an intake can't overcome
and i'd go w/ a 2000 GT fed spec and do a front kit swap so you can have the better looking front end
Don't act like you don't love it.
503/2000
Old 06-21-2005, 04:36 PM
nailzer's Avatar
nailzer nailzer is offline
Re: GT vs. GTS
the GT has a 9:1 compression ratio and the GTS has a 10:1 compression ratio, which makes the GT better for super/turbo charging.
Old 06-21-2005, 11:54 PM
Sleepr awd's Avatar
Re: GT vs. GTS
...yes, thank you nailzer for your contribution...
503/2000
