Old 06-19-2005, 11:14 PM
Stealth-Twinturbo Stealth-Twinturbo is offline
1st Gen intercooler upgrades
I have a 92 stealth and i want to do an intercooler upgrade HKS side mounts are 1500 is there anything cheaper??
92 Stealth R/T TT
CURRENT MODS:
K&N FIPK
Spec Stage 3 Clutch 6 Puck
HKS Turbo Timer Type-1
3 Inch Polished Y-Pipe
Greddy Profec B Spec II @ 12.0psi
Greddy Type S BOV
Greddy Catch Can
Borla Exhaust
3 Inch SS Down Pipe with Race Pipe
3SX Crank Pulley
Accel 8.0mm Wires
Gen 3 Lifters
High Flow 290lph Fuel Pump (Supra Pump)
Plugs Gapped at .030 Iridium IK20's
550cc RC Engineering
Apexi S-AFC II (WILL BE REMOVED NOT YET)
2 G-16 Turbos
AEM EMS
FUTURE MODS:
Custom FMIC
Old 06-19-2005, 11:56 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 1st Gen intercooler upgrades
yea, Custom Coach has a cheaper deal: http://www.geocities.com/speedpartsrus/3000gt.html ...but they've been out of stock for sometime. you might call/e-mail and see what's up.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-20-2005, 08:49 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: 1st Gen intercooler upgrades
You want cheap?? DSM side mounts are an upgrade for ya. It looks to me like you are still on stock turbos so a front mount is a bad idea. They are not enought to pressurize the system and it could cause you to lose power. The DSM side mounts however have been proven to help with even a stock car.
Old 06-20-2005, 04:32 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
NO I A WAY BETTER DEAL www.dejontool.com their FMIC kit is only $1300. a front mount 10x bretter than side mounts.
Upgrades... To many to list...
Old 06-20-2005, 04:53 PM
Stealthee's Avatar
Not on stock turbos its not better. It is proven that a front mount and stock turbos can cause you to lose power. They are just too small to pressurize it.
Old 06-20-2005, 08:27 PM
Hotshot8792 Hotshot8792 is offline
a front mount is not 10x better than the dsm sidemounts. They are better than them, but not that much better.
The best bang for your buck are 1st gen DSM sidemounts, they flow more than any other sidemount intercoolers there are. They aren't bolt on, but, you can get both for around $80, then take them to a welding shop along with your old intercoolers, have them either make custom piping or cut the piping off your old intercoolers and weld them on the new intercoolers, plus they'll have to cut and flip the top of one of the intercoolers i believe.
All i know, it cost me 80 shipped for both intercoolers and 250 for the labor to make them directly bolt on. You wont get anything nearly as good as those for even triple the price.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-20-2005, 09:27 PM
92VR4Red's Avatar
honestly a front mount would be more pressure because their is less tubing and no flex because there is no rubber hoses... if its all solid, then there is no flex...
Old 06-20-2005, 10:25 PM
Stealthee's Avatar
Look it up. A front mount will harm your power on smaller turbos.
Old 06-20-2005, 10:40 PM
no, its less pressure
the piping length isn't going to increase or decrease pressure, its the volume, and the rubber piping has nothing to do with the pressure.
Basically, a front mount intercooler has more volume to fill than stock intercoolers, therefore the turbos have to pump more air to fill it up before getting it into the engine. On stock turbos, they dont flow enough air to fill up the extra volume so it will do more harm than good. Now on turbos that will fill up the volume, it will do lots of good.
Old 06-22-2005, 08:19 PM
As long as you don't buy a ridiculously big front mount you would be ok just buy a small front mount intercooler.
92 Stealth R/T TT
CURRENT MODS:
K&N FIPK
Greddy Type S BOV
Greddy Catch Can
Borla Exhaust
3SX Crank Pulley
Accel 8.0mm Wires
Gen 3 Lifters
2 G-16 Turbos
AEM EMS
FUTURE MODS:
Custom FMIC
Old 06-22-2005, 08:30 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Ahh, gotta love myths. Is this coming from anyone who actually has a FMIC??? You will not lose power.The worst case you will have is not getting boost till 2-300 rpm later than before. However the gains far outweight the 2-300 rpm loss. The intake air will be cooler and the presure drop across the intercooler will be signifigantly less, so you may even end up holding more presure to redline.
However, if you are on stock turbos I would deffinatly just go with DSM sidemounts. They are way cheeper and will do you just as much good.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 06-22-2005, 09:35 PM
Stealthee's Avatar
Well I was going by different things I have read. I do however find what you say interesting and will look into it more.
Old 06-22-2005, 10:05 PM
well actually, it might be true, i know two WRX owners, both with the same mods and both on stock turbos. One has a upgraded front mount and one has an upgraded top mount, in which the top mount doesnt flow as much as the front mount, and the guy with the top mount is faster.
Old 06-23-2005, 03:08 AM
slightly different story, they are 2 diff cars, with 2 different drivers even if they have the same mods. top mount VS front mount is also a far leap from twin side mounts VS front mount. With a top mount on a WRX there is at most a foot of piping, that is not the case with side mounts.
Old 06-29-2005, 10:03 AM
trbo3o2 trbo3o2 is offline
I just registered on this list but there is a guy around me here in michigan that builds custom intercoolers for cheper than that. Go to www.toohighpsi.com and click on the Jim's coolers link. You should be able to find it there. And, just a side note. The people who are saying the turbo's are not big enough to fill the large front mount intercooler are completely incorrect due to the law of conservation of mass. It basically states that mass cannot be created nor destroyed. If the engine does not use anymore air, There is no reason that a loss in pressure or power shold occur. It will, however, take longer to pressurize the larger volume. The decrease in intake temperature should make up for the increase in lag time. Most importantly, what are your intake temps? What is the pressure drop across the intercooler you have now? Ask youself these questions before you blow a whole bunch of cash on something that may not help at all.
