Old 06-19-2005, 09:24 PM
Tonyr's Avatar
Tonyr Tonyr is offline
replacing fuel filter
Can someone tell me where the fuel filter is on my 2000 SE?
Thank you very much!
Old 06-20-2005, 07:20 AM
Hoags's Avatar
Hoags Hoags is offline
Re: replacing fuel filter
The fuel filter is most likely located behind the gas tank. You may also need a special tool to remove the old filter, you should be able to pick one up at the parts store when you get your filter.
Make sure to use protection when changing the filter, you will get gas comming from the filter and fuel lines.
Good luck.
