Old 06-19-2005, 07:54 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
stupid fuel injector
so i installed a new auxillary fuel injector on my dual point hatch. the green one. but the screws were super stripped and i havent found any to replace them yet. so i ran it without the metal cage and now the injector leaks big time. any quick fix for a while at least until i can get another metal cage? can i steal the metal cage from the top one?
gimme some time. ill think of something witty and clever to put here.
Old 06-20-2005, 02:21 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
I think I've taken those metal things off with out anything leaking at all...are you sure it isn't the other seals?
Old 06-25-2005, 10:33 PM
Re: stupid fuel injector
oj so i pulled th4einjector out. no problems. the first oring was broken so i replaced that. then i put the fuel injector back. and started the car. it drove fine until i parked it and let it sit. then i started it up like two hours later and it leaked again
Old 06-27-2005, 10:05 PM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
injector troubles
what was your car runnning like woth the bad injector? I think I may have the same problem?
Thanks
"If you can read this...I'm Parked!..............Or broke down."
