Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-19-2005, 07:01 PM
STB STB is offline
1991 Caprice Smoke coming from Crankcase. Help!
This is the problem. I got a '91 Caprice 5.0 305, it used to be a police intercepter. I had a friend who works at a Chevy dealer and he came over and told me I had a Leak at the Valve Cover and told me I needed a Valve cover gasket. So, I went and got a gasket. Had to take this off and that off and took me about 3 hours to do it(1st time doing it) and I went to drive it and I could smell smoke.I open the hood and saw alittle smoke coming from the Right side of the engine ( But I put the gasket on the Left side). So, in my Caprice there is a needle OIL GAUGE inside and it has 0-30-60 in the middle is 30 and it floats under 30. It runs good and the OIL dipstick is showing that it is filled. But there is little drops of oil that leaks over the drain plug under the Caprice. The Filter in on tight and the plug is on tight. I don't have a freakin' clue what is going on. Thanks for the Help if possible.
Old 06-21-2005, 09:04 AM
chaney3000's Avatar
chaney3000 chaney3000 is offline
Re: 1991 Caprice Smoke coming from Crankcase. Help!
You put the valve cover gasket on the opposite side of the leak. Always replace both valve cover gaskets at the same time. It will save you a lot of trouble in the long run.
First thing, go pressure/ steam clean your engine at a carwash to get all the old oil off so you can see where the leak is coming from. Look around the valves and the PCV valve to make sure they aren't leaking. Next look lower to make sure your oil pan gasket is not leaking. Hopefully, your rear main seal isn't leaking.
Old 06-23-2005, 10:52 PM
STB STB is offline
The leak was on the left side (passenger) and put the new gasket on the left side (passenger). I check the gasket that I put on and it is not leaking. Check the PCV valve and that is o.k.. I put new clamps on all hoses that I had to disconnect to get to the Valve cover. And I check the oil drain plug and the filter again and both are tight and not leaking. Check the dipstick and it shows the same amount it has always shown, FULL. I don't understand what is the problem.
Old 06-26-2005, 03:14 AM
Morley Morley is offline
Back side of the intake manifold may be leaking. With the engine cool, run your fingers along the seam between the engine block and intake in the back and see if your come up oily. If so...have fun, I hate changing intakes on carb cars.
Old 06-26-2005, 09:45 AM
HLandin's Avatar
HLandin HLandin is offline
What makes changing the intake gaskets more work on carbs than a fuel injected version?
Old 06-27-2005, 10:31 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
alot more little connections and crap like that
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 06-27-2005, 04:01 PM
STB STB is offline
Hey Dude, How much did it cost to fix up you Caprice like that? Mine is pure white and it has 155,000 miles on it. I got it from a old man I used to help that Willed it to me when he past away. I would like to fix it all the way up, and drop a bigger engine in it and the whole nine yards.
Old 06-27-2005, 04:07 PM
STB STB is offline
I checked it again and I don't understand. If it was leaking shouldn't it be loosing on the dipstick? The Dipstick says it is Full.
Old 06-27-2005, 05:33 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
odds are its a slow leak, and you won't notice it for a little while. Mine used ta leak tons of oil all over my driveway from the oil pan gasket, and it took about a month for the oil level to go down a quart.
Old 06-29-2005, 01:54 AM
Re: Re: 1991 Caprice Smoke coming from Crankcase. Help!
just a little bit of nice black oil will go a long ways when on the ground
